04-19-2018, 18:19 | #6 (permalink) |
Freak Poster Join Date: May 2011 Location: algeria
Member: 1582098 Status: Offline Thanks Meter: 17 | same here i have win7 x64 1.58 runs just fine version 2.0 does not even show no errors nothing. is'nt there a debug option or log file to check for the error ? |
04-19-2018, 20:16 | #8 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Austria
Member: 1050590 Status: Offline Thanks Meter: 148 | Hello also my cm2 mtk2.00 not open... System Win 8.1 64 bit Version 1.58 and other modules run ok... After starting V2.00 i noticed that just this 2 more processes "COM Surrogate" are started, after 4 seconds there are closed.... nothing happens... no start 2.00.. BR |
04-19-2018, 21:45 | #9 (permalink) | |
Member: 1582098 Status: Offline Thanks Meter: 17 | Quote:
@YellowBoss the issue seems to be on Win7 x64 version , i just tried on Win7 x32 works fine. i have no sharing/trace/sniff/debug software installed if it was the case no other tools like nck or falcon or z3x will work . even the 1.58 version will not also | |
04-20-2018, 05:25 | #10 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
04-20-2018, 07:19 | #11 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
But before i got a same problem, I solved it by Uninstalling Uni-An......tool.Delete CM2MT2 Folder,Restart pc.Install MT2 again. Up to Now Mt2 works fine. | |
04-20-2018, 08:02 | #13 (permalink) | |
Member: 1050590 Status: Offline Thanks Meter: 148 | Quote:
I have Uni-An... too, but this was not mine problem... Both tools run at the same time on my laptop... Itīs mystical BR | |
04-20-2018, 08:02 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | COM Surrogate itself not should affect startup issues. Probably some SW or something similar doesn't allow CM2 module finish enivorment check. |
04-20-2018, 08:08 | #15 (permalink) | |
I remember i had HASP Driver for another software installed.. maybe this could have been the reason why MT2 didnīt start BR | |
