08-02-2020, 00:53 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Tabligbo
Member: 1032123 Status: Offline Sonork: akeal81 Thanks Meter: 29 | Itel a14 flash ok but restart I GET ITEL A14 DEAD I TRY FLASH USING A14-SA215-8.1-OP-V001-20180608.pac BUT THE PHONE BUT RESTART WHILE CONFIGURING.I FLASH WITH A14-SA215-8.1-OP-V031-20190301.pac BUT STEAL THE SAME THERE IS LOGS Card found : 7370D1EA , v0144 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! VER : BP_R1.0.0 LEN : 57A3E746 ( 1,37 GiB ) CPU : sp7731e_1h20 VER : MocorDroid8.1_Trunk Open : A14-SA215-8.1-OP-V001-20180608.pac VER : BP_R1.0.0 LEN : 0x57A3E746 ( 1,37 GiB ) CPU : sp7731e_1h20 VER : MocorDroid8.1_Trunk Reading package ... Read package finished! Patch Level : OPM2.171019.012 Display ID : A14-SA215-8.1-OP-V001-20180608 Ver. Incmt : 06080004 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-05-05 Build Time : 1528387498 Product Model : itel A14 Product Brand : Itel Product Name : SA215 Product Device : itel-A14 Product Manfct : itel Product Info : itel A14 Product Board : sp7731e_1h20 Board Platform : sp7731e Operation : Flash Firmware [ v2.05 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : A14-SA215-8.1-OP-V001-20180608.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat CODE : delta_nv.bin CODE : PIKE2_DM_DSP.bin CODE : pike2_cm4.bin CODE : gnssbdmodem.bin CODE : gnssmodem.bin CODE : PM_pike2_cm4.bin CODE : boot.img CODE : recovery.img FSIMG : system.img FSIMG : userdata.img CODE : logo.bmp CODE : logo.bmp FSIMG : cache.img FSIMG : vendor.img ERASE : W_RUNTIMENV1 ERASE : MISC CODE : tos-sign.bin CODE : sml-sign.bin UBOOT : u-boot-sign.bin FSIMG : persist.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:08:00 Card found : 7370D1EA , v0144 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! VER : BP_R1.0.0 LEN : 57218EA5 ( 1,36 GiB ) CPU : sp7731e_1h20 VER : A14-SA215-8.1-OP-V031-20190301 Open : A14-SA215-8.1-OP-V031-20190301.pac VER : BP_R1.0.0 LEN : 0x57218EA5 ( 1,36 GiB ) CPU : sp7731e_1h20 VER : A14-SA215-8.1-OP-V031-20190301 Reading package ... Read package finished! Patch Level : OPM2.171019.012 Display ID : A14-SA215-8.1-OP-V031-20190301 Ver. Incmt : OP-V031-20190301 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 1551432243 Product Model : itel A14 Product Brand : Itel Product Name : SA215 Product Device : itel-A14 Product Manfct : ITEL MOBILE LIMITED Product Info : itel A14 Product Board : sp7731e_1h20 Board Platform : sp7731e Operation : Flash Firmware [ v2.05 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : A14-SA215-8.1-OP-V031-20190301.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat CODE : delta_nv.bin CODE : PIKE2_DM_DSP.bin CODE : pike2_cm4.bin CODE : gnssbdmodem.bin CODE : gnssmodem.bin CODE : PM_pike2_cm4.bin CODE : boot.img CODE : recovery.img FSIMG : system.img FSIMG : userdata.img CODE : logo.bmp CODE : logo.bmp FSIMG : cache.img FSIMG : vendor.img ERASE : W_RUNTIMENV1 ERASE : MISC CODE : tos-sign.bin CODE : sml-sign.bin UBOOT : u-boot-sign.bin FSIMG : persist.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:08:51 PLEASE HELP ME FIX THIS PROBLEM THANKS FOR ADVANCE |
08-02-2020, 08:53 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Update with NVM enabled in settings too. Check result. Backup NV , try reflash with forced NVM update and check result. Restore your NV backup after. Make sure first about device not became hot and power consumption in power on condition is okay, before reflash it. |
