09-15-2018, 16:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Itel A15 Secure Boot, Read Flash, Repair Security Fail Code: Start at : [15/09/2018 / 14:17:01] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2018-04-25.11:26_437806 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 700100454838454434010A928E524511 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4DE8H [eMMC] : FLASH_CID : 700100454838454434010A928E524511 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x24760925970B6D4E1FAA7B9DB5DEA788 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Itel ProdName : VP510 ProdModel : itel A15 Device : itel-A15 AndroidVer: 8.1.0 [Read Ok] : preloader_k80hd_bsp_fwv_512m.bin [Read Ok] : persist.img [Read Ok] : lk.bin [Read Ok] : lk2.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Stop] : Unknow data! Make next steps : 1. Use WinRar or 7zip and rar this folder : MT6580__Itel__itel_A15__itel-A15__8.1.0__ 2. Send this archive with title "FWFACT" to [email protected] Read error :( Operation Failed Elapsed: 00:00:57 Reconnect Power/Cable! Finish at : [15/09/2018 / 14:17:59] Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : AT+EGMR=0,0 HW : AT+EGMR=0,4 SW : AT+EGMR=0,3 MM : AT+EGMR=0,1 VR : AT+EGMR=0,2 SN : AT+EGMR=0,5 Security Info : IMEI [1] : AT+EGMR=0,7 IMEI [2] : AT+EGMR=0,10 IMEI [3] : AT+EGMR=0,11 IMEI [4] : AT+EGMR=0,12 Read Ok! Update IMEI[1] to : 355796091309645 failed , record not exist or NVRAM damaged! Update IMEI[2] to : 355796091309520 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:01:32 Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2018-04-25.11:26_437806 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 700100454838454434010A928E524511 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4DE8H [eMMC] : FLASH_CID : 700100454838454434010A928E524511 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x24760925970B6D4E1FAA7B9DB5DEA788 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error on Security Repair , Code : 0x2 Make sure about mobile is working and alive! Check BaseBand state also, fix if need! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! |
09-16-2018, 07:43 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Am seeing this http://forum.gsmhosting.com/vbb/13319316-post53242.html |
09-16-2018, 14:20 | #6 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
But read flash & repair security not supported ATM. | |
