03-31-2019, 13:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | itel a16 plus 8.1 signed firmware flash write done Loading : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 FastCheck : 0x005B908760 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img File : sp7731e_1h10.xml Load Ok! Operation : Read NV [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:30 Reconnect Power/Cable! Set mode to : [AltLDR] SP [SC773x] eMMC [Android 7.x] Loading : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 FastCheck : 0x005B908760 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img File : sp7731e_1h10.xml Load Ok! Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:30 Reconnect Power/Cable! Set mode to : [AltLDR] SP SC77xx [Model Select] Loading : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 FastCheck : 0x005B908760 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img File : sp7731e_1h10.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : A16Plus-SA332-8.1-OP-V004-20180907.pac CRVersion : BP_R1.0.0 PacCPUinfo : sp7731e_1h10 PacVersion : A16Plus-SA332-8.1-OP-V004-20180907 File : fdl1-sign.bin File : fdl2-sign.bin File : pike2_pubcp_PLD_base_nv_nvitem.bin File : prodnv.img File : u-boot-spl-16k-sign.bin File : vbmeta-sign.img File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat File : delta_nv.bin File : PIKE2_DM_DSP.bin File : pike2_cm4.bin File : gnssbdmodem.bin File : gnssmodem.bin File : PM_pike2_cm4.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : vendor.img File : tos-sign.bin File : sml-sign.bin File : u-boot-sign.bin File : persist.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x20 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : w_fixnv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : VBMETA Current File : vbmeta-sign.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W_DELTANV Current File : delta_nv.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_GSM Current File : PIKE2_DM_DSP.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DFS Current File : pike2_cm4.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : GPS_GL Current File : gnssbdmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : GPS_BD Current File : gnssmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : PM_pike2_cm4.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : VENDOR Current File : vendor.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_W Current Part : w_runtimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : CODE Current ID : TRUSTOS Current File : tos-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : SML Current File : sml-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot-sign.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : PERSIST Current File : persist.img Flashing now ... [FlashProc] : Ok! Elapsed: 00:05:21 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to kothamamun For This Useful Post: |
