02-01-2023, 16:10 | #1 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | iTEL A58 LTE A631W FRP RESET DONE ADB MODE Code: Operation : Identify (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device Info : Vendor : ITEL Model : itel A631W Device : SA368N1 Android : 11 Product : A631W Brand : Itel Serial : 08**************** Build_tm : Mon Jun 27 20:41:26 WIB 2022 DisplayID : A631W-SA368N1-11.0-OP-V001-20220623 Patch Ver : RP1A.201005.001 SecPatch : 2022-06-05 Hardware : A631W HW Board : A631W CPU rel : armeabi-v7a SIM Card : ABSENT,ABSENT BaseBand : FM_BASE_17C_W22.09.5|sc7731e_modem,FM_BASE_17C_W22.09.5|sc7731e_modem RIL ver : android reference-ril 1.0 USB Conf : adb Sys USB : adb FS Crypt : encrypted OEM Unlck : 1 Done! Elapsed: 00:00:12 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : SA368N1 Model : itel A631W FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:15 |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
02-02-2023, 15:40 | #3 (permalink) |
Member: 2996196 Status: Offline Thanks Meter: 632 | just install ADB drivers , then use CM2 AST tool connect fone at welcome , Click reset FRP on ADB tab . it shows adb debugging notification then allow . Then restart device make reset from menu Note all devices can be enabled ADB debugging, you try some may fail |
The Following 2 Users Say Thank You to Jacobkamudyariw For This Useful Post: |
