12-02-2017, 19:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: morrocco
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | Itel it2150 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! |
12-02-2017, 22:50 | #2 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | It is a classic new phone Boot incorrect you must open phone and see what is cpu inside . Sc.... ??? What Sent from my SM-G530H using Tapatalk |
12-03-2017, 11:33 | #4 (permalink) |
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | SPRD mode : SC6531 : REV : E000 : NOR Operation : Read UserCode [ v1.01 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] STATE : ACTIVE : CODE : 2334281 Done! Elapsed: 00:00:24 |
04-19-2018, 09:05 | #6 (permalink) |
Freak Poster Join Date: Sep 2013
Member: 2033319 Status: Offline Thanks Meter: 98 | new it2150 flash file flash this file with cm2scr module https://learnflashing.com/itel-it215...31e-flash-file |
The Following User Says Thank You to hamtech For This Useful Post: |
04-19-2018, 10:05 | #7 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
If you have good flash files and if you want to share it with other users please use http://forum.gsmhosting.com/vbb/f296...oader-2001567/ Please do not upload password protected or damaged files, all of them will be deleted after upload. | |
The Following User Says Thank You to princesaddam For This Useful Post: |
05-14-2018, 18:42 | #8 (permalink) | |
Freak Poster Join Date: Mar 2015 Location: Nairobi
Member: 2358876 Status: Offline Thanks Meter: 78 | THIS IS A NEW CHIP SC6531E....Not available yet Quote:
Not yet available | |
05-15-2018, 22:43 | #10 (permalink) |
Junior Member Join Date: Jun 2014 Location: Nigeria
Member: 2204758 Status: Offline Thanks Meter: 5 | Download infinity scr module...I have done up to 10pieces Sent from my M5 using Tapatalk |
The Following User Says Thank You to drviktor99 For This Useful Post: |
