03-17-2023, 12:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Uganda
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 149 | nokia c20 ta-1352 format faile help Card found : xxxxxxx , v0154 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset Settings [ Format FS ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:20 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe failed! Reconnect Power/Cable! Done! Elapsed: 00:00:19 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe failed! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 |
03-17-2023, 19:02 | #2 (permalink) | |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | Quote:
