04-29-2019, 18:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | itel p33 frp remove infinity team , need cm2spd for remove frp for spd android 8.1 . i m trying to remove it to one itel p33 with yr cm2spd without solution. need help |
06-01-2019, 12:08 | #3 (permalink) |
Crazy Poster Join Date: Apr 2016
Member: 2553878 Status: Offline Sonork: [email protected] Thanks Meter: 16 | help me remove frp itel P33 |
06-01-2019, 12:24 | #5 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | try this method and post result here http://forum.gsmhosting.com/vbb/13675757-post31.html |
06-01-2019, 12:24 | #6 (permalink) |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | This is loader for itel p33, just paste it in sp2 itel module. https://mega.nz/#!IOZwQCbI!oNbh9KfY4...m41NugSuHS6T7o |
06-01-2019, 16:50 | #7 (permalink) |
Member: 2812901 Status: Offline Thanks Meter: 493 | ITEL P33 FRP DONE BY GREAT CM2 SPD/USC Module [SP2] You don't need loader !!! JUST SELECT SC7731E_eMMC_1GB_RS.fg............ Card found : 5B5B5BXX , v0137 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1 Operation : Identify [ v2.00r1 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.00r1 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Done! Elapsed: 00:00:42 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:40 |
The Following 6 Users Say Thank You to Oyetunde Semiu For This Useful Post: |
07-25-2019, 14:12 | #9 (permalink) |
Junior Member Join Date: Nov 2017 Location: bangladesh
Member: 2775443 Status: Offline Thanks Meter: 2 | boot done Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! |
The Following User Says Thank You to sha mehedi For This Useful Post: |
08-06-2019, 11:51 | #10 (permalink) |
Member: 2553878 Status: Offline Sonork: [email protected] Thanks Meter: 16 | 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:32 |
The Following 3 Users Say Thank You to BOUAGSM For This Useful Post: |
09-13-2019, 07:54 | #12 (permalink) |
Junior Member Join Date: Aug 2014 Location: philippines
Member: 2234249 Status: Offline Thanks Meter: 6 | Card found : 968304B3 , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:03:10 |
The Following 3 Users Say Thank You to alfajeff For This Useful Post: |
