Itel P33 sc7731e privacy lock My itel P33 have privacy lock I try to select the boot Sc773x but not success to bboot the phone |
Use firmware Quote:
FLASH by using factory firmware to flash the device SPD Privacy solutions is not yet out all you need is Factory firmware FRP and privacy will be out all locks |
Bro can share some link. I'm sorry |
CHECK in BOX Quote:
I will send you in pm |
Privacy lock in SPD based phone? Never seen that before. |
I tell you bro. Privacy lock on ITEL P33. |
same not work bro. I try the flash file |
Explain better Quote:
You mean you have flash the file and it's still having same Problem or you are unable to flash the firmware? |
Bro, post logs of operations you have performed with tool so far here for help. Did you try to perform 'reset settings' with tool by selecting sc773xC android 6.0 boot option? And if you did, what happened? You need to post logs here. |
@DIDIER2009 if it's not solve then contact me on telegram i will try to solve your issue @kamal_singla |
I download a fix file from a site and it worked, just 177 KB |
still no want to shrared bro Quote:
hi bro try to Helps Us for remove privacy on this fone reply as possible |
https://www.itel-mobile.com/global/support/downloads/ |
Itel p33 can't be download through that link. It write error. |
