07-29-2021, 23:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Uganda
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | itel p36 device is managed by organization phone format ok. phone flashing ok write nvram ok but phone phone still locked. since the phone is mortgage, the lack of securitycomponents causes the phone to be locked. |
07-30-2021, 14:42 | #4 (permalink) |
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | Card found : XXXXX , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : W6501-F3111-9.0-OP-V023-20200605 Ver. Incmt : OP-V023-20200605 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Build Time : 05.06.2020 Product Model : itel W6501 Product Brand : Itel Product Name : F3111 Product Device : itel-W6501 Product Manfct : itel Product Info : W6501 Product Board : W6501 Board Platform : sp7731e Product Name : W6501 Product Device : W6501 Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P5 HW Version: sc7731e_modem CMP_Time : 12-25-2019 16:59:14 MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P5_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:04:57 Operation : SP Unlock [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 387008875XXXXXX IMEI[2] : 3870088XXXXXXXX IMEI[3] : 8674000XXXXXXXX WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 SLStatus : 01 Device not locked! Done! Elapsed: 00:00:27 |
07-30-2021, 14:43 | #5 (permalink) |
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | Phone info Card found : XXXXXX , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : W6501-F3111-9.0-OP-V023-20200605 Ver. Incmt : OP-V023-20200605 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Build Time : 05.06.2020 Product Model : itel W6501 Product Brand : Itel Product Name : F3111 Product Device : itel-W6501 Product Manfct : itel Product Info : W6501 Product Board : W6501 Board Platform : sp7731e Product Name : W6501 Product Device : W6501 Platform Version: MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_ITEL_RLS2_W19.28.5_P5 HW Version: sc7731e_modem CMP_Time : 12-25-2019 16:59:14 MODEM TAG : MOCORTM_17C_ITEL_RLS2_W19.28.5_P5_Debug_FM_BASE_17 C_ITEL_RLS2_W19.28.5_P5_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:04:57 |
08-02-2021, 09:13 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Please, read FW and send for check. Before pack it, remove SYSTEM/VENDOR/CACHE/USERDATA images from FW to reduce size. |
08-02-2021, 15:17 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | didnt found any spec-lock. Did you try power on device Without sim card after flash/reset and it still show same message, correct? Did you try write other NVRAM in "NO" mode ( unsafe write , request during writeNV operation ) |
08-03-2021, 08:04 | #9 (permalink) |
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | how to write nv in NO mode??? sir how can i write nv in no mode. another thing is phone pops up error without simcard that says phone locked since the phone is in mortgage, the lack of security components causes the phone to be locked. automatically unlock after downloading security component. |
08-03-2021, 09:16 | #10 (permalink) |
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 148 | Operation : Write NVM [ v2.13 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W6501 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0001 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVRM : 356660501935465__w_fixnv1.nvm NVMng : Init DST NVMng : NVM block updated! NVMng : Post-Processing Reconnect Power/Cable! Done! Elapsed: 00:00:50 write nv with no but phone still locked |
08-03-2021, 12:58 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Most probably, it belongs to certify components, used by unisoc ( like TEE/Google keys ) , have no idea. Without any test sample on hands it hard to find anything working fast. Also, one more way to try - complete erase and reflash, as a way. But not sure in result. |
08-05-2021, 21:33 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | First make all possible backups, then flash factory firmware. If still the same - it's under some specific lock as @JayDi already mentioned. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
