Old 06-08-2021, 20:57   #1 (permalink)
Member: 2809120
Thanks Meter: 83
itel S16 Pro cannot be connected with CM2
hi
i try to remove FRP on Itel W6503 S16 Pro without success
Operation : Format FS / Reset Settings [ v2.12 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
>>> ERROR : FDL NOT started!
>>> Error : Fail to boot FDL!
>>> Unsupported device with selected fdl or settings! Change settings!
Reconnect Power/Cable!
Operation : Identify [ v2.12 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
>>> ERROR : Protocol HandShake failed!
>>> Error : Fail to init protocol!
>>> Remove battery, cable. Check cable and connection. Repeat operation!
BootMode : FLASH
Card found : 21B1154E , v0148
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.12
Load IDBase v8331 Ok!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
so i wnat to know if infinity support this phone
Old 06-08-2021, 22:29   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
To know the correct boot, 1s of all connect phone in diag mode.
Old 06-09-2021, 08:52   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Itel mostly uses OWN sign keys, so connect as ITEL.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 06-09-2021, 18:52   #4 (permalink)
Member: 2601900
Thanks Meter: 519
S16 is a signed phone so even he read the phone in diag it won't mean a thing, the only option for him is to use pac file in cm2spd2 to service his phone, i hope team will add itel, mobicel and tecno spd phones soon
Old 06-09-2021, 20:25   #5 (permalink)
JayDi's Avatar
Member: 462970
What? Itel and rest already in list.
https://forum.gsmhosting.com/vbb/14407864-post37.html
Old 06-10-2021, 05:40   #6 (permalink)
Member: 2809120
Thanks Meter: 83
itel S16 PRO W6503 CORRECT STEP TO REMOVE FRP
Hi Sir JayDi
below link discussion is regarding flash of itel S16 W6502 not remove FRP on Itel S16 Pro W6503, i found flash file of S16 Pro W6503; so i want to know how to remove FRP on this itel W6503, using flash file which is on support.
thanks for your help
regards
Old 06-10-2021, 05:50   #7 (permalink)
Member: 2809120
Thanks Meter: 83
Hi Jaydi
on above post is regarding flash of itel S16 W6502 wich will be supported by next update 2.13.
My question is about itel S16 pro W6503 with FRP
i found flash file on support ; so please i would like to know how to remove FRP on this phone using current firmware which is on support
thanks for your explanation
regards
leroi
Old 06-10-2021, 05:56   #8 (permalink)
Member: 2809120
Thanks Meter: 83
Hi
thanks for your advices, but on current 2.12 version there is not any W6503 option to services on Itel Tab
Old 06-10-2021, 07:07   #9 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by leroi2018 View Post
Hi
Link to test version has been sent in PM.
Old 06-10-2021, 08:56   #10 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
ZTE Z3 First Time Cannect 2nd Time Not Cannect
Patch Level    : PPR1.180610.011
Display ID     : PK_ZONGZ3_A5_2019_V1.0
Ver. Incmt     : 20191224.142013
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-12-05
Build Time     : 24.12.2019
Product Model  : Z3
Product Brand  : ZTE
Product Name   : P963F30P
Product Device : P963F30P
Product Manfct : ZTE
Product Info   : P963F30P
Product Name   : s9863a1h10_Natv
Product Device : s9863a1h10
Product Board  : lucyzh64
Board Platform : sp9863a
Platform Version: MOCORTM_18B_W19.10.2_ZLA_P16_Debug
Project Version:   sharkl3_pub
BASE  Version:    FM_BASE_18B_W19.10.2_ZLA_P16
HW Version:        sc9863A_modem
CMP_Time : 11-19-2019 18:08:48
MODEM TAG : MOCORTM_18B_W19.10.2_ZLA_P16_Debug_FM_BASE_18B_W19.10.2_ZLA_P16_sc9863A_modem_sharkl3_pub
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption ***)
 - > INFO : Remove cable from device to switch it off!
Done!
Elapsed: 00:02:02
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : INFINITY FW PACKAGE
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
>>>   ERROR : FLASH FDL NOT started!
Old 06-10-2021, 09:21   #11 (permalink)
JayDi's Avatar
Member: 462970
Ver. CodeName  : REL
Ver. Release   : 9
Product Model  : Z3
Product Brand  : ZTE
Done!
Elapsed: 00:02:02
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Always post complete logs, because have no idea about FIRST settings and then see other ones.
Old 06-10-2021, 11:00   #12 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
How To Setting Change
Ver. CodeName  : REL
Ver. Release   : 9
Product Model  : Z3
Product Brand  : ZTE
Done!
Elapsed: 00:01:23
Open : SPD_PROG.xml
Reading package ...
Read package finished!
Created by Infinity-Box (c) 2020
Chinese Miracle II : Spreadtrum / UniSoc Service Module
Device Info file   : _Android_info.txt
Ver. CodeName  : REL
Ver. Release   : 9
Product Model  : Z3
Product Brand  : ZTE
SECSolution : MODERN [RS/0S/1S/2S]
Operation : Flash Firmware [ v2.12 ]
Setting   : Update NVRAM : False
Setting   : Force NVRAM : False
Setting   : Update PMT   : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Old 06-10-2021, 15:32   #13 (permalink)
Member: 2809120
Thanks Meter: 83
hi Sir Jaydi
i did not received the soft via PM.
regards
leroi
Old 01-18-2022, 01:59   #14 (permalink)
Member: 2314220
Which boot did you sellet sir
Old 01-18-2022, 19:27   #15 (permalink)
Member: 148515
Thanks Meter: 19,534
loader file is at Infinity support area iTel_S16_Pro_W6503_FDL
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Page generated in 0.28888 seconds with 8 queries
