GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   itel S16 Pro cannot be connected with CM2 (https://forum.gsmhosting.com/vbb/f296/itel-s16-pro-cannot-connected-cm2-2974870/)
leroi2018 06-08-2021 20:57
hi
i try to remove FRP on Itel W6503 S16 Pro without success
Operation : Format FS / Reset Settings [ v2.12 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
>>> ERROR : FDL NOT started!
>>> Error : Fail to boot FDL!
>>> Unsupported device with selected fdl or settings! Change settings!
Reconnect Power/Cable!
Operation : Identify [ v2.12 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
>>> ERROR : Protocol HandShake failed!
>>> Error : Fail to init protocol!
>>> Remove battery, cable. Check cable and connection. Repeat operation!
BootMode : FLASH
Card found : 21B1154E , v0148
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.12
Load IDBase v8331 Ok!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
so i wnat to know if infinity support this phone
Yusuf Lawal 06-08-2021 22:29
To know the correct boot, 1s of all connect phone in diag mode.
JayDi 06-09-2021 08:52
Itel mostly uses OWN sign keys, so connect as ITEL.
mmtheo 06-09-2021 18:52
S16 is a signed phone so even he read the phone in diag it won't mean a thing, the only option for him is to use pac file in cm2spd2 to service his phone, i hope team will add itel, mobicel and tecno spd phones soon
JayDi 06-09-2021 20:25
What? Itel and rest already in list.
https://forum.gsmhosting.com/vbb/14407864-post37.html
leroi2018 06-10-2021 05:40
itel S16 PRO W6503 CORRECT STEP TO REMOVE FRP
Hi Sir JayDi
below link discussion is regarding flash of itel S16 W6502 not remove FRP on Itel S16 Pro W6503, i found flash file of S16 Pro W6503; so i want to know how to remove FRP on this itel W6503, using flash file which is on support.
thanks for your help
regards
leroi2018 06-10-2021 05:50
Hi Jaydi
on above post is regarding flash of itel S16 W6502 wich will be supported by next update 2.13.
My question is about itel S16 pro W6503 with FRP
i found flash file on support ; so please i would like to know how to remove FRP on this phone using current firmware which is on support
thanks for your explanation
regards
leroi
leroi2018 06-10-2021 05:56
Hi
thanks for your advices, but on current 2.12 version there is not any W6503 option to services on Itel Tab
JayDi 06-10-2021 07:07
Originally Posted by leroi2018 (Post 14408300)
Hi
Link to test version has been sent in PM.
Tanha0321 06-10-2021 08:56
ZTE Z3 First Time Cannect 2nd Time Not Cannect
Patch Level    : PPR1.180610.011
Display ID    : PK_ZONGZ3_A5_2019_V1.0
Ver. Incmt    : 20191224.142013
Ver. CodeName  : REL
Ver. Release  : 9
Sec. Patch    : 2019-12-05
Build Time    : 24.12.2019
Product Model  : Z3
Product Brand  : ZTE
Product Name  : P963F30P
Product Device : P963F30P
Product Manfct : ZTE
Product Info  : P963F30P
Product Name  : s9863a1h10_Natv
Product Device : s9863a1h10
Product Board  : lucyzh64
Board Platform : sp9863a
Platform Version: MOCORTM_18B_W19.10.2_ZLA_P16_Debug
Project Version:  sharkl3_pub
BASE  Version:    FM_BASE_18B_W19.10.2_ZLA_P16
HW Version:        sc9863A_modem
CMP_Time : 11-19-2019 18:08:48
MODEM TAG : MOCORTM_18B_W19.10.2_ZLA_P16_Debug_FM_BASE_18B_W19.10.2_ZLA_P16_sc9863A_modem_sharkl3_pub
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption ***)
 - > INFO : Remove cable from device to switch it off!
Done!
Elapsed: 00:02:02
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : INFINITY FW PACKAGE
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
>>>  ERROR : FLASH FDL NOT started!
JayDi 06-10-2021 09:21
Ver. CodeName  : REL
Ver. Release  : 9
Product Model  : Z3
Product Brand  : ZTE
Done!
Elapsed: 00:02:02
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Always post complete logs, because have no idea about FIRST settings and then see other ones.
Tanha0321 06-10-2021 11:00
How To Setting Change
Ver. CodeName  : REL
Ver. Release  : 9
Product Model  : Z3
Product Brand  : ZTE
Done!
Elapsed: 00:01:23
Open : SPD_PROG.xml
Reading package ...
Read package finished!
Created by Infinity-Box (c) 2020
Chinese Miracle II : Spreadtrum / UniSoc Service Module
Device Info file  : _Android_info.txt
Ver. CodeName  : REL
Ver. Release  : 9
Product Model  : Z3
Product Brand  : ZTE
SECSolution : MODERN [RS/0S/1S/2S]
Operation : Flash Firmware [ v2.12 ]
Setting  : Update NVRAM : False
Setting  : Force NVRAM : False
Setting  : Update PMT  : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
leroi2018 06-10-2021 15:32
hi Sir Jaydi
i did not received the soft via PM.
regards
leroi
simeon uche 01-18-2022 01:59
Which boot did you sellet sir
InfinityHelp 01-18-2022 19:27
loader file is at Infinity support area iTel_S16_Pro_W6503_FDL
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.17916 seconds with 6 queries
