05-16-2018, 23:08 | #1 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | SUPERTAB S7G KRC1032 : cm2 spd 1.27 + ast 1.03 logs Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! ******************************************** Set mode to : SP [SC773x] eMMC [Android 5.x] Start at : [16/05/2018 / 22:48:28] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable *****cm2 spd freez force close ************************************************** * Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! ********************************************** Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! ****************************************** Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Set mode to : [AltLDR] SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! ********************************************** Set mode to : [AltLDR] SP [SC773x] eMMC [Android 6.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! ******************************************** Set mode to : [AltLDR] SP [SC773x] eMMC [Android 7.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! ************************************************** log with cm2 ast 1.03 Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device Info : Vendor : SPRD Model : SuperTabS7G Device : sp7731gea_hdplus_dt Android : 5.1 Product : scx35_sp7731gea_hd Brand : SuperTab Serial : 56188245439943 Build_tm : 2017年 10月 13日 星期五 18:36:33 CST DisplayID : s706a_cuser_20171013 Patch Ver : LMY47D Hardware : sc7731 HW Board : sp7731gea_hd CPU rel : armeabi-v7a SIM Card : ABSENT,NOT_READY BaseBand : TM_BASE_MP_II_W15.26|sc7731g_CP0_modem|06-23-2015 14:29:29 BaseBand : TM_BASE_MP_II_W15.26|sc7731g_CP0_modem|06-23-2015 14:29:29 RIL ver : android reference-ril 1.0 USB Conf : mass_storage,adb Sys USB : mtp,adb FS Crypt : unencrypted Done! Elapsed: 00:00:12 ************************************************ hello team i have this new tablet in market : supertab s7g krc1032 and i want to read flash but no success i think this tab have a new chips if cm2 spd 1.27 can't support it. i hope this tab can be supported in futur update think you. |
05-16-2018, 23:19 | #2 (permalink) |
Member: 2671513 Status: Offline Thanks Meter: 121 | Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 5.x] Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
05-17-2018, 00:48 | #3 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Load firmware, then try to flash. Download : SP7731GEA_HD_scx35_sp7731gea_hd_5.1_s706a_cuser_20 160325_SuperTabS7G Quote:
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
05-17-2018, 22:23 | #4 (permalink) | |
Member: 2671513 Status: Offline Thanks Meter: 121 | Quote:
Chinese Miracle II [SPD module] v 1.27 Set mode to : SP SC77xx [Model Select] Infinity SC Firmware Detected FW Size : 1336 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : SuperTab Device Model : scx35_sp7731gea_hd Device CPU : sp7731gea_hd Device IntName : sp7731gea_hdplus_dt Device Version : 5.1 Device Compile : 25-03-2016 6:10:34 Device Project : s706a_cuser_20160325 Device ExtInfo : SuperTabS7G Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! ***************************************** Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 38 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! *********************************** this tablet is supertab s7g krc1032 i have a friend who have a mobile shop and every time he give me new mobile or tablet to read flash and this time he gived me this tab and no success | |
07-21-2018, 15:15 | #10 (permalink) |
Freak Poster Join Date: Jun 2011 Location: ilution
Member: 1597314 Status: Offline Thanks Meter: 116 | many phone spd chipset have fdl lock,need fdl original from factory firmware for boot this phone.and much phone have firmware with new extensi file,exm cpb file.. i hope infinity tim can create custom load fdl1 and fdl2 from factory file for boot,this usseful for resset frp without flashing.. |
The Following User Says Thank You to pshycoboy For This Useful Post: |
08-02-2018, 16:38 | #13 (permalink) |
Junior Member Join Date: Jan 2009
Member: 956826 Status: Offline Sonork: tad 60 Thanks Meter: 4 | only for format and frp reset hard reset use in pac file krc 1021 downlowd from ****tun-droid**** after use cm2spd(select sc7030.....android 5.x) |
The Following User Says Thank You to tad60 For This Useful Post: |
