03-13-2016, 09:36 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: pakistan
Member: 319303 Status: Offline Thanks Meter: 22 | its hardware problem? Code: Operation : Check / Read Info [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404050FA138F66133 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBF0B0000 EMICFG_RET_FAILED Boot Error! Operation Failed Elapsed: 00:01:18 Reconnect Power/Cable! |
03-13-2016, 14:52 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Depend on moments : if selected original FW - then it mean something wrong with HW ( eMMC/DRAM if separate IC ) If not selected FW - internal base can contain different DRAM settings, which are not match to that eMMC. If mobile is dead - then seek for FW, if alive - not need hold any boot key. |
