Old 11-13-2010, 12:46   #1 (permalink)
Member: 1114818
Thanks Meter: 247
urgent .to infinity team
hello sir .
after tray to unlock sfr 151 my phone is dead now .only power on with white screen i faormat it after that but same prob
he the log from unlock operation:
COM3 [VCP0] selected
module v3.64
Device: SFR-151
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:4A1C:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC227E22632260:2CEA0000000000
flash: Micron/Silicon7 AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
rom info detection finished
rom info ver: 07
sw version: M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z525_ C136_HW3_SW2_V7_05.BIN
project-id: Z525.C136.HW3.SW2.V7.05, 00000000
code offset: 00000000
ffs offset/size [02]: 01800000/00800000
TCL-ID is absent
ffs/eeprom address assigned: 01800000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: SFR-151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__ffs...
file saved: C:\Program Files\InfinityBox\MModule\SFR-151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__ffs_20101113-123030.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
error: phone is not locked or unknown eeprom
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 8 min 50 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to jbenianamohsen For This Useful Post:
Old 11-13-2010, 12:47   #2 (permalink)
Member: 1114818
Thanks Meter: 247
log from format ffs
module v3.64
Device: SFR-151
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 07
TCL-ID is absent
file saved: C:\Program Files\InfinityBox\MModule\SFR-151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__ffs_20101113-124046.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 6 min 37 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 11-13-2010, 12:52   #3 (permalink)
Member: 1114818
Thanks Meter: 247
phone is powred on with flash file
module v3.64
Device: SFR-151
Action: write flash
"smart write" active
write: Firmware
sfr 151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__firmware_20101026-221116.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 07
TCL-ID is absent
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 58 sec
i used this file for revive it sfr 151_M23_Z525_C136_HW3_SW2_PCB01_GPRS_MT6223P_S00.Z 525_C136_HW3_SW2_V7_05__firmware_20101026-221116.B0M.bin
The Following User Says Thank You to jbenianamohsen For This Useful Post:
Old 11-13-2010, 13:02   #4 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Try to unlock phone now with "smart fast" unlock method.
Old 11-13-2010, 13:10   #5 (permalink)
Member: 1114818
Thanks Meter: 247
Originally Posted by YellowBoss View Post
Hello,
ok just few seconde i post resulta
Old 11-13-2010, 13:15   #6 (permalink)
Member: 1114818
Thanks Meter: 247
phone still locked
module v3.64
Action: "sp-unlock"
unlock method: smart fast
Model: SFR-151
19200 autodetect
CPU: MT6223
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: Z525.C136.HW3.SW2.V7.05
Version: YUANDA23C_09A_HW
86 byte(s) read
imei: 35868800000015
connection Ok
193 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
181 byte(s) read
reading data...
188 byte(s) read
warning: unknown lock mode: BC000000
error: data is invalid
Finished, time used: 17 sec
Old 11-23-2010, 12:59   #7 (permalink)
Crazy Poster
Member: 1126773
Thanks Meter: 11
Originally Posted by jbenianamohsen View Post
hello sir .
module v3.64
Device: SFR-151
Action: "sp-unlock"
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 07
TCL-ID is absent
required data found
====> Write ...
Write: ffs
Write Done
Finalization Done
I have same problem, when i hold power button i see this error:nvram_sec.c, 657, 29243 29754 0
For repair you have to flash it with a firmware available in infinity support, phone will power up but phone still locked
The Following User Says Thank You to achlhiy For This Useful Post:
Old 11-24-2010, 20:45   #8 (permalink)
Member: 288908
Thanks Meter: 2
hi,
plz i have a same problem with sfr 151
i flashed it with firmware ho where in support a support and now is dead
plz infinity help me to solve this problem.
tankx
Old 01-12-2011, 23:28   #9 (permalink)
Member: 1094669
infinity team
please help everyone have same problem after unlock screen becomes white phone doesnt start shows white screen with mention nvram ...........
Old 01-13-2011, 09:24   #10 (permalink)
mscomp's Avatar
Member: 266158
Sonork: 131654654654
Thanks Meter: 198
flash with flash on support all will be ok if not do format ffs
after flash
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.25833 seconds with 9 queries
