J110i unlocking problem... I have problem, i connect phone select comport, press unlock and have COM3 selected Device: Sony-Ericsson J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now when press power button nothing happend, any sugestions? br, fingusio |
hi dear put the cable in the phone only when software ask you to Press Power button now |
I try also, but not work. Now i must return phone to customer and test other trick :( Maybe in future when i will be have some. br, fingusio |
its new protected boot.....u cant conect |
ps : maybe problem in cable or phone connector:D |
@zinoubinabil Impossible, because i emulate COM port by JAF and also don't work. Any reaction for power buttom. I only add that phone was new from T-Mobile Germany. br, fingusio |
Sorry, double post. br, fingusio |
All Known J110i Is Supported But Many Pple Have Problem With Comunicattions..when Sw Say Power Conect Cable 2 Fone ..other Dan Remove Battery And Put In ..b R Damabib |
then i dont lie you are bad informed about your own box :D |
it is 100% working on all J110, j120 regards guide Quote:
i have tried to unlock 3 or 4 phones j110i and they all success but when i insert the sim it says incorrect sim card it shows successful but after this incorrect sim card so not complete solution yet |
hello! probably eeprom area damaged after other tool. make "repair" |
Dear Friend, Small advice: it's always good idea don't say "incomplete solutuion" if you did not tried to make unlock/repair correctly. You must use latest software from support area and make "unlock" or "repair" procedure. Also, when people write only text "not work" instead of explain the problem (and post software operation logs) this means that somebody just want to say "not work" w/o any reason. Please, think about this in future when you will try to write something here. |
2day i succesfully unlock 2 j110i phone.ist tym i getting pvlm but after i solve.power on phone and wen says press power botton n hold then off phone and again press pwr btton.datz ok. |
j110i Quote:
