j132 ips unlock done another ps unable to unlock here is log which one is all ready i done COM41 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090428-143548.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 86 sec Remove/Install battery now ! |
here is log which one i cant unlock \ COM41 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 52 sec Remove/Install battery now ! |
Cable Port Problem I Think Bro |
s1 platform with new security cant be unlock free yet need credit via server ... |
work like cham did you try with choose t250 and do spunlock big thanks to infinity for there good job dB :) |
@digital babu I think which one have u tried that may not witn new security |
pls check my both post again .both set boot version are same .how to i confrim this is new security ?.if boot version different then i am confrim this is new security . |
pls check my both post again.both are boot version same . |
It's not a problem with new security, it's a problem with cable. It is need to double check cable and try again. |
try to also fg port but same problem COM15 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... rom version: 0502 booting... finalizing... Boot fail error: operation failed Finished, time used: 66 sec Remove/Install battery now ! |
bro if cable problem how can i sucess 1st one ? |
your cable is ok .Check with setool if same problem than you can unlock it with setool with 2 credits. if you want to check CPU version than Dissamble the phone and see difrence between unlocked phone and locked. BR NADIR |
problem also with setool v0.915016/UNI CARD SERIAL: 00053310 Loaded 51 flash descriptors PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed FAILED TO SETUP PHONE Elapsed: 17 secs. |
hello infinity team need answer |
