09-07-2016, 18:34 | #1 (permalink) | ||
Freak Poster Join Date: Jun 2014 Location: ALL THINGS ARE POSIBLE WTH ***
Member: 2203712 Status: Offline Sonork: 100.1667064 Thanks Meter: 82 | Jaydi kindly look at this for me THEN I READ FIRMWARE FROM A WORKING FONE, AFTER FLASHING IT FOR THE FIRST TIME, IT WAS STILL HANG ON LOGO. THEN I FLASHED IT WITH FLASH ERASE TICKED, BUT THE FONE NOW VIBRATES AND NOTHING ELSE. KINDLY HELP ME OUT THE FIRST FLASH Quote:
Code: Start at : [9/7/2016 / 5:14:48 PM] Operation : Flash [ v1.21 ] ======= Flash Files set for flashing : [ MCU ] : HS011_HS011_5.1_HS011_14B_test-keys_X551.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : SC7731_eMMC_HS011_5.1_HS011_14B_INFINITY-BOX File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin File : logo_540x960.bin File : fblogo_540x960.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 34 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : sc7731g_CP0_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_Gx.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : fblogo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Error with code 0x0002 Elapsed: 00:05:21 Reconnect Power/Cable! | ||
09-08-2016, 01:59 | #4 (permalink) |
No Life Poster Join Date: Jul 2011 Location: dunia antah berantah
Member: 1616754 Status: Offline Thanks Meter: 245 | check your battery bro... Your battery may run out or the remainder below 20% if not detecting..try push the button repeatedly boot spreadtrum must use battery or use power supply.. maybe it can help you |
09-08-2016, 07:01 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Charge battery, flash with update NVM. Also make sure firmware which you are trying to write has same HW Rev. Br. Infinity Box Support Team. |
09-08-2016, 07:23 | #6 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
