Old 02-16-2021, 07:46   #1 (permalink)
Member: 2401943
Thanks Meter: 182
Jazz Digit 4G v2 Downgrade problem
[FL] : Flashing now ...
Write : PRELOADER
FAIL : SEC : PL VFY FAIL
ERR : 0xC0020006
ERR : SEC : PL VFY FAIL
ERR : 0x00000000|0x0001BEE0
Error : Flashing failed!
>>> Seems as something wrong with device! Check battery charge and device state!
Anyone have tested file ?
Here is backup info, only this file flashble, MT6739__alps__Digit4G__4.4.2__Digit_M42421DG_EF 2_SW03_20201125_1046__KOT49H__Digit4G all other files get error,
Operation : Read Firmware [ v2.21 ]
ExtSparse : Enabled
ForceRead : Disabled
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM28)
MODE : BOOTROM
PORT : 28
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
CODE : Zion
TYPE : MODERN RAPHAEL
BROM : MEID : C098C0A79880FCE46735087D9573CE60
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Enabled
BROM : SOCID : 6F7F67F94A99E1C745A8B7AD5213615E0D076EA7D0DA526518 FE79ABA585A2D9
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6739
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6739
EMI : SRC : preloader_fise6731_kaie_s_e_k.bin
EMI : CNT : 0006
EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ]
EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ]
EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ]
EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ]
EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ]
EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x20000000 [ 512.00 MB ]
EMMC: 90014A48344732611102C3A2C2B265DD
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H4G2a
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE9000000 [ 3.64 GB ]
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 5AB36B2AA4701E8C6DEAD289E8D9798E
DA : USB : HIGH-SPEED
Boot done!
Patch Level : KOT49H
Display ID : Digit_M42421DG_EF2_SW03_20201125_1046
Ver. CodeName : REL
Ver. Release : 4.4.2
Build Time : 25.11.2020
Product Model : Digit4G
Product Brand : Digit
Product Name : Digit4G
Product Device : Digit4G
Product Manfct : alps
Board Platform : mt6739
Product Info : Digit4G
MT6739__alps__Digit4G__4.4.2__Digit_M42421DG_EF2_S W03_20201125_1046__KOT49H__Digit4G
Read : preloader.bin
Read : recovery.img
Read : proinfo.img
Read : md1rom.img
Read : md1dsp.img
Read : spmfw.img
Read : mcupmfw.img
Read : nvram.bin
Read : lk.bin
Read : loader_ext.img
Read : boot.img
Read : logo.bin
Read : tz.img
Read : system.img
ExtSparse : Compression ratio : 56%
Read : cache.img
Read : userdata.img
FW Size : 519.41 MB
Android Info saved : _Android_info.txt
Scatter : MT6739_Android_scatter.txt
Saved to : D:\MT6739__alps__Digit4G__4.4.2__Digit_M42421DG_EF 2_SW03_20201125_1046__KOT49H__Digit4G\
Done!
Elapsed: 00:01:47
Old 02-16-2021, 08:43   #2 (permalink)
fahadboss's Avatar
Member: 2441366
Sonork: Telegram: @FahadBoss10
Thanks Meter: 245
I have readed same firmware from working phone.
Old 02-16-2021, 08:44   #3 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 245
Old 02-16-2021, 09:33   #4 (permalink)
Member: 2401943
Thanks Meter: 182
i need downgarde flash file for v2, i try many files, after flash dead, only readout file flash done.
Old 02-17-2021, 12:58   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
V1 and V2 firmware NOT COMPATIBLE BETWEEN THEM!
Old 03-26-2021, 16:55   #6 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 112
I need This file backup any one have upload and share link
Old 03-26-2021, 17:34   #7 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 245
Jazz Digit4G v2 (New Board) Firmware:
https://drive.google.com/file/d/1rvl...ew?usp=sharing
Sent from my LG-H820 using Tapatalk
Old 03-26-2021, 19:56   #8 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
how do you know your phone is V2 or V1 ?
Old 03-26-2021, 20:01   #9 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
can you put your phone on fast boot mod without downgrade ?
do you see V2 on back sticker?
Old 03-27-2021, 04:38   #10 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 245
You know it by back sticker of the phone.
You can clearly see difference in both.
In new model, digit logo is on the upper side and battery 1700 mAh is also mentioned.
This file is of new model.
The Following 2 Users Say Thank You to fahadboss For This Useful Post:
Old 03-27-2021, 13:27   #11 (permalink)
Member: 2831700
Thanks Meter: 394
Jazz Digit 4G V1 Fix After Flash Dead Solution By CM2
http://www.youtube.com/watch?v=o-c9rPsxMqI
Gsm Iqbal Khan
Old 03-27-2021, 13:59   #12 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
bro I have solution only for V1 , if you could find solution and done unlocking let me know please
your reply would greatly appreciated
The Following 4 Users Say Thank You to khanzada606 For This Useful Post:
Old 05-09-2021, 11:35   #13 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
file have pass..............
Old 05-15-2021, 11:31   #14 (permalink)
Member: 2490814
Sonork: MOIGSM.com
Thanks Meter: 21
bro i need new board file
Old 06-01-2021, 14:28   #15 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
file password isigicomDigit4Gv2
The Following User Says Thank You to khurram136 For This Useful Post:
Page generated in 0.19866 seconds with 8 queries
