Jazz Digit Booted in sla Dead now Hi infiniry Team today i flash jazz digit by select 0 base boot 1944 set flashed normally but after i mistakenly i flashed same device in sla mode then device software errased and preloader write err plz how to solve this problem Code: Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Code:
maybe hardware fault what was the problem with the phone when you got it for repair ? |
1st i flashed without problem set was alive then i flashed tick sSLA and flash again [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002E88000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x0000000009500000 : 0x0000000007200000 Erase : 0x0000000010C00000 : 0x0000000000200000 Erase : 0x0000000010E20000 : 0x00000000D71DBE00 |
sSLA have nothing to do with forced device killing by yourself. Flash now CORRECT firmware from V1 or V2 HW revision, which your device was. |
[QUOTE=Ahsaan*;14325295]Phone was alive i want repair security 1st i flashed without problem set was alive then i flashed tick sSLA and flash again [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002E88000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x0000000009500000 : 0x0000000007200000 Erase : 0x0000000010C00000 : 0x0000000000200000 Erase : 0x0000000010E20000 : 0x00000000D71DBE00[/QUOTE This phone came with 3 new hw version one is old but different security version and another one is v1 and v2 Did you checked before flash which version was installed in phone And another thing ssla is only for boting phone its like a da file |
i need full model number i can help u |
Wrong version I think you have written wrong version, You have written version 4.4.2, infect Jazz Digit 4G new version is 6.0, Please check that first. |
brother i have readed today file i wil uplaod for u |
i have jazz digit4g v3 new security dead after flashing v7 hw any one can get solution or tested firmware please :confused::confused::confused::confused::confused: |
Jazz Digit V3 dead after downgrade falash recovery file MT6739__alps__Digit4G__4.4.2__Digit_M42421DG_EF2_S W04_20210203_1019__KOT49H__Digit4G https://www.gsmsofts.com/index.php?a...b=file&id=1145 |
@mwk2712 Do you mean you recovered phone with given file? File T6739_alps_Digit4G_4.4.2_Digit_M42421DG_EF2_SW04_2 0210203_1019_KOT49H_Digit4G.7z can be downloaded from Infinity Support Area long time ago. Use Firmware File Finder via Telegram @FlashFileSearchBot https://cdn.infinity-box.com/tg/bot-...ile-search.png |
