Old 02-14-2009, 08:43   #1 (permalink)
Miftahudin's Avatar
Member: 115242
Sonork: 100.1581364
Thanks Meter: 1,638
JAZZ Hauwei T161L Successfully Unlocked with Infinity Box
Instruction
Open infinity Shill select Hauwei T161L then run in next page Select Model Hauwei T128
Press unlock after unlock done u need to put code 12345678 with non accepted sim card
Here is the log
COM9 [VCP0] selected
Device: Huawei-T158
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
460800
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-sta_20090214-122920.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-sec_20090214-122928.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-complete_20090214-122934.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 36 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
Current model: Huawei-T128
The Following User Says Thank You to Miftahudin For This Useful Post:
Old 02-14-2009, 08:50   #2 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
bro miftahuddin its old news and why u gave typical instruction that
"Open infinity Shill select Hauwei T161L then run in next page Select Model Hauwei T128 Press unlock after unlock done u need to put code 12345678 with non accepted sim card ".
bro we can simply select in main shell t161l and unlock this model as others no need to put unlock code and no need to select huawei t128 model tested many times.
Old 02-14-2009, 08:55   #3 (permalink)
Member: 52404
Thanks Meter: 2
bro its not bad if he post unloking logs here
even if its old news for us but
infinity team neeed more and more unloking Test logs details for make
infinty-box more powerfull
hope u understand
T.N
The Following 2 Users Say Thank You to tauseef For This Useful Post:
Old 02-14-2009, 09:02   #4 (permalink)
Member: 355565
Sonork: 1597522
Thanks Meter: 95
good work bro keep it up
Old 02-14-2009, 09:11   #5 (permalink)
Miftahudin's Avatar
Member: 115242
Sonork: 100.1581364
Thanks Meter: 1,638
Bro we have lots of new *******rs many time have problems in unlocking
So I have posted the logs and instruction for help new customers
And I have saved the link if any one any time need instruction then easily new user
can get The help…….
If u have any problem then inform me
Br.
The Following 2 Users Say Thank You to Miftahudin For This Useful Post:
BenQ-Siemens E52 Successfully repair with infinity box dog_baby Infinity-Box 5 05-19-2009 11:49
Huawei T128 Successfully Unlock With Infinity .::AZEEM::. Infinity-Box 11 01-13-2009 19:01
Huawei T128 Successfully Unlock With Infinity , Again A Great Work Team. amit_varietymob Infinity-Box 8 08-30-2008 07:08
Spice S535 Successfully Unlocked With Infinity amit_varietymob Infinity-Box 8 06-24-2008 19:23
Siemens CFX 65 is successfully unlocked with Infinity mcandre Infinity-Box 4 12-04-2007 12:52
Page generated in 0.18734 seconds with 9 queries
