12-20-2008, 09:38 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 144091 Status: Offline Thanks Meter: 73 | JM-5700 can't be unlocked-help can be detected but cannot do any, like read fullflash/eeprom and sp-unlock. is this phone supported? why it's in the list. what you i do? TIA here is the log of pinfinder software version: 1.16 cable type: 1x18 (L18A) platform: PMB: Infineon e-gold searching adapter at COM3... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (820000) result: Rx:11 Tx:15 time required: 78 sec saved: jm-5700 Power On ! log of Infinity COM3 [VCP0] selected module v1.58 Device: J-Max-JM5700 Checking data, wait... Action: read flash Boot ... Press and HOLD Power button now ! loading... next part... error: can't run main loader: Finished, time used: 5 sec Remove/Install battery now ! |
12-20-2008, 16:34 | #5 (permalink) |
Member: 144091 Status: Offline Thanks Meter: 73 | ohhh.. no! this unit becomes problematic. i tried to unlock it using Infinity SW ZTE 225 and it's running but after unlock signal is now failing to register to any network, since i made backup i tried to flash with it but told me file is corrupted. now i downloaded flash file from support and flash it but now phone is dead! pls Infinity Team help me how to solve this... thanks this now the corrupted flashfile original from phone http://rapidshare.com/files/17518258...24550.B1X.html |
12-20-2008, 16:54 | #6 (permalink) |
Member: 144091 Status: Offline Thanks Meter: 73 | here is the log when i used flash file from support COM3 [VCP0] selected module v1.58 Device: ZTE-225FM Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225FM_eeprom-static_20081220-234132.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225FM_eeprom-security_20081220-234133.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225FM_eeprom-complete_20081220-234139.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 456 sec Remove/Install battery now ! after flashing here is the result only blue lights in keypad |
12-20-2008, 18:20 | #8 (permalink) |
Member: 144091 Status: Offline Thanks Meter: 73 | Thanks advance sir do i need to upload saved eeprom of this phone? one more thing there is something bug in SW Pan1. Since ZTE 225 could detect the phone make flash as easy while selecting its own SW JM5700 has errors. kindly check also. TIA |
12-20-2008, 22:33 | #9 (permalink) | |
It's no need to upload eeprom. Connection: we can see that one day users say that connection was good one way, next day users say that connection was done other way etc. etc. So I think that this kind of Chinese phones is one more joke from China, phones with the same name has different hardware. We will try to make something to improve situation and my request to users: post here PCB photo (in good quality) so we will be able to see PCB difference for the same models. | |
12-20-2008, 23:55 | #11 (permalink) | |
Member: 144091 Status: Offline Thanks Meter: 73 | Quote:
ill post result after flashing...thanks a lot | |
12-21-2008, 00:20 | #12 (permalink) |
Member: 144091 Status: Offline Thanks Meter: 73 | Hey Infinity Team...with hugs and kisses!!! Thank you very much! The Phone is working fine again!!! In fact it's unlocked with good signal. three thumbs up for this. |
The Following User Says Thank You to lix_DAVAO For This Useful Post: |
AMOI MD2 can't be unlocked!!!! HELP | B52 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 11 | 10-18-2009 20:26 |
KU990i can't be unlocked help Micro-Box team | B52 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 09-08-2009 07:03 |
Nokia 6630 can't be unlocked by JAF No Tp unlocker, help! Logs. | kevinyin | JAF No Tp Unlocker by Cinek | 4 | 02-07-2009 14:18 |
What phones soft versions can't be unlocked by free JIC unlocker???? | Tygiel | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 12-20-2002 19:07 |
Sagem MW932 FF3,1N - can't be unlocked? | kreitzz | Infineon C16X M51 & ARM7 M52 BASED | 7 | 04-28-2002 04:43 |
