11-03-2009, 09:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ina 4 sure
Member: 911645 Status: Offline Thanks Meter: 19 | k-touch a691 dead i got 2 pcs k-touch a691 dead. it is mt6228 i couldn't find its flashfile in support area, so i used language pack edit to convert bin universal file to one that supported w/ CM here's log when i flash it: Code: COM2 [VCP0] selected module v2.96 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware editor_corrected_A691-2.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only rom info protocol ver: 04 ver. sw 1: TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN ver. sw 2: 073316_741_V1219, 26F67B16 address offset: 00000000 ffs offset/size: 01900000/06700000 warning: ffs size mismatch: 066FF800/06700000 nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 07 loader: 3.0840.00.00 NAND id: 98F18095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done load emi configuration... apply emi configuration... ram size: 02000000 emi configuration done NOR: 0000:000000000000 [00000000] NAND: 0098:00F100800095 [08400000] NOR chip is not installed Initialize Done Set baud ... 230400 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure (chip)... source data: page only rom info protocol ver: 04 ver. sw 1: TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN ver. sw 2: 073316_741_V1219, 26F67B16 address offset: 00000000 ffs offset/size: 01900000/06700000 nfi area detection finished: Ok detecting bootloader structure (source file)... source data: page only rom info protocol ver: 04 ver. sw 1: TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN ver. sw 2: 073316_741_V1219, 26F67B16 address offset: 00000000 ffs offset/size: 01900000/06700000 nfi area detection finished: Ok rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished startup code area #1 check... warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB.[TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN_167BF626].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB._TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN_167BF626_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.27EADFDB.[TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN_167BF626].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.27EADFDB._TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN_167BF626_.rpl ==================== warning: unknown rom info structure: TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN_167BF626 Unknown firmware detected (v.2.96, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TYM073316_741_PCB04_GPRS_MT6228_S02.073316_741_V1219.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? Identification Done Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_system_log_27EADFDB_167BF626_20091103-155418.B4X.bin 00006000 bytes sent write core area 1 of 2... 00422000 bytes sent write core area 2 of 2... 011DC000 bytes sent Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_system_log_27EADFDB_167BF626_20091103-161353.B4X.bin Finished, time used: 1267 sec Remove/Install battery now ! what could the error be? 1. is it its flash file (i used two source of flash file)? 2. is this type -somehow- is not supported yet? 3. is it hardware failure? fyi: tried already to full-flash using another tool (cpf-box, spiderman), got no error message, but phone is still dead |
11-03-2009, 20:24 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if all boxes gives same result- i think you must turn to phone hardware check, not software |
Htc Touch Elf Dead | elassooudi | HTC & PDA WM( With Touchscreen) | 5 | 09-13-2009 05:33 |
Help --> K-Touch A615 Dead by Infinity., Fatal | dj.orion | Infinity-Box | 5 | 03-24-2009 20:47 |
Help K-touch A691 | dany_kroya81 | Chinese Models & Cloned Phones | 3 | 09-30-2008 21:22 |
Alcatel One Touch Easy..DEAD! | iqballk | Alcatel TCL Hardware Repair | 6 | 10-13-2002 06:24 |
