Old 09-29-2010, 01:24   #1 (permalink)
Member: 744651
Thanks Meter: 20
K688 cannot write IMEI
Hi Masters,
I have here a K688 dual sim phone, a chinese copy of the HTC Snap. I have several of them that i needed to format complete to sort out some software issues.
However, after format, i cannot write the imei to them, they are MT6235 and i use mode one and two, but nothing, even set rate to autodetect and have set to NAND.
I have even tried to write imei to units some ofthem even before format, but still nothing.
Here a log from one of my attempts:
COM10 [VCP0] selected
module v3.07
Action: "repair imei"
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono CPU
new imei: 35768801000xxxx
Model: Autodetect 6228-6239 NAND
Checking data, wait...
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: E702_BLJ1K2.01.0
Version: EVEN35_08B_HW
detecting structure #2...
1 4 5 7 8 9 11warning: wrong packet cs
12 16 19 20 22 23 24 26 27error: detection failed (16 tries), read flash and send to support
connection Ok
4 5 7 8 9 11 12 16 19 20 22 23 24 26 27error: detection failed (16 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 15 sec
Remove/Install battery now !
Your help as always will be welcome.
Old 09-29-2010, 17:21   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i had similar phone yesterday, we had to modify software to make IMEI writing done.
same story with your phone. please upload your phone flash file to rapidshare and post hre link
Old 09-30-2010, 03:13   #3 (permalink)
Member: 744651
Thanks Meter: 20
Hi Masters,
Thanks for your quick reply, i have read firmware on one of these units and uploaded files to rapidshare as you requested.
This is the link:
http://rapidshare.com/files/42223583...184533.B4M.bin
I have two questions:
1) after you have this file, then what?....will you give me solution here?...please advise.
2) this is just a read of one unit, i have 9 units that need to flash, do i have to read all of them and send you individual files?
You quickest response will be greatly appreciated.
Thanks Masters!
Old 09-30-2010, 18:46   #4 (permalink)
Member: 148515
hello!
if all 9 phones is same version- then 1 backup is just enough.
we will check this file and improve software.
i will let you know what to do next
Old 09-30-2010, 19:54   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@DualSimCell
File downloaded, I hope new software will be released in short time.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-01-2010, 12:45   #6 (permalink)
Member: 130995
Try to repeat operation but this time use latest ChineseMiracle update from support area.
What is the results ?
Old 10-07-2010, 00:45   #7 (permalink)
Member: 744651
Thanks Meter: 20
Hi Masters,
Ok, so I installed latest version of Chinese Miracle, but still same, no problems to perform a format.
When trying to write IMEI, it's just reaching to the point where it says "Connecting" and does not coonect.
Your quickest response on a solution would be greatly appreciated.
Thanks
Old 10-07-2010, 21:08   #8 (permalink)
Member: 148515
hello!
show us IMEI changing methods 1 and 2 with latest CM software 3.24
Old 10-08-2010, 01:00   #9 (permalink)
Member: 744651
Thanks Meter: 20
Hi Master,
Ok, here ya go, i'm using pinfinder V1.2 and Chinese Miracle V3.24
First Format, here is a read:
module v3.24
Device: Autodetect 6228-6239 NAND
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0058]: 002C:00A100800095 [MICRON] MT29F1G08ABB
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 03000000/05000000
firmware size: 48Mb
ffs size: 80Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: E702_BLJ1K2.01.0
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
external bootloader is not present
bootloader version: E702_BOOTLOADER_V005_MT6235B_01_1.bin
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 05
sw version: E702_BLJ1K2_PCB01_GPRS_MT6235B_S01.01_0.BIN
project-id: E702_BLJ1K2.01.0, 00000000
code offset: 00000000
ffs offset/size [01]: 03000000/05000000
rom info structure: [standard] type (05)
TCL-ID is absent
===> done
Format (HW_STORAGE_NAND)...
Disconnect...
done
Finished, time used: 3 min 13 sec
********* WRITING IMEI#2 WITH MODE-2 **********
module v3.24
imei write channel: imei #2 for dual sim/mono CPU
new imei: 3570688000*****
19200 autodetect
CPU: MT6235
high speed boot On
status: FF
rom: 4D573031
error: can not finalize test mode
repeat operation and HOLD phone "Power" button more long time !
Finished, time used: 2 min 33 sec
************WRITING IMEI#2 WITH MODE-1
Phone should be Switched ON !
Connecting, wait...
error: connection failed !
If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect")
operation failed !
Finished, time used: 1 min 12 sec
I'm tried different setting and all the same, really confused here, because connection for format is great, but to write IMEI, as you can see...nothing.
Old 10-08-2010, 17:06   #10 (permalink)
Member: 148515
hello!
best way now is to try change IMEI over bluetooth.
IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum
try it and reply
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.21918 seconds with 9 queries
