01-09-2009, 18:43 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: IN YOUR HEART
Member: 109163 Status: Offline Thanks Meter: 75 | K700 after 2 minut going to white display i try to ffs: safe format its not done log here COM16 [VCP6] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:9703:0003 Connecting, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27error: detection failed (28 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! full format is supported problem still. then i try REPAIR SECURITY AREA.. COM16 [VCP6] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:9703:0003 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.A288_V3_32. BIN ver. sw 2: A288_V3.32, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done Finished, time used: 45 sec Remove/Install battery now ! readed details information: COM16 [VCP3] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7703:0008 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.A288_V3_5.B IN ver. sw 2: A288_V3.5, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ....................... detect standard fat location pass #1... ................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ....................... detect standard fat location pass #1... ................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 57 sec also i try by flashing same another good readed firmware and eprom problem stilll........... |
01-09-2009, 21:02 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It may be that you need to flash phone with similar (but not exactly the same) firmware version like installed in phone now. Also, if you have full flash backup from good working phone pls send it to [email protected] and include in your mail problem description. |
01-12-2009, 18:01 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We have got flash backup. It was found nothing wrong in file. Possible problem reason: it may be bug in firmware (factory bug). What to do: it is need to flash phone with other firmware that has similar version (but not the same as already installed in phone). Firmware version should be similar to CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.A288_V3_5 Also I suggest you to contact to persoin who sold to you these phones and ask him to contact factory. |
Harold & Kumar Go To White Castle (Simple pack DVD) (US Version) (USA) (Region 1) | IPMART | ipmart WebShop | 0 | 08-08-2009 10:30 |
Harold & Kumar Go To White Castle (Simple pack Blu-ray) (US Version) (USA) (Region 1) | IPMART | ipmart WebShop | 0 | 08-08-2009 10:30 |
6280 switch off after 2 minute. | ales6orah | Nokia Base Band 5 ( BB-5 ) | 5 | 03-06-2007 12:21 |
Sagem mc922 writes sagem and after some minutes go away! | asmax1 | Infineon C16X M51 & ARM7 M52 BASED | 4 | 06-21-2004 18:47 |
3330 switches off after 2 minutes | GSMWolf | Nokia Hardware & Hardware Repair | 4 | 03-28-2003 10:52 |
