05-28-2015, 08:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Infinity box CM2SPD 6531a can read Info by Chance But... Code: Start at : [5/28/2015 / 3:39:46 AM] Operation : Check/Read Info [ v1.01 ] Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCOR_12B_6531.W13.07_Debug ExtInfo : F3006_BOPAI_059_S5_128X64_272X480_S_L6 Project : F3006_BP059_50_SX_S5_128X64_272X480_NOWIFINOTV_L6_V04.04B02 HWInfo : F3006_BP059_50_SX_S5_128X64_272X480_NOWIFINOTV_L6_V04.04B02 Compile : 11-20-2014 10:27:06 Phone Security Info : IMEI [1] : 351804066194713 IMEI [2] : 351804066194721 BT_ADDR : 443504155539 Done! Elapsed: 00:00:18 READ FLASH Code: Start at : [5/28/2015 / 3:40:11 AM] Operation : Read FullFlash [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [5/28/2015 / 3:40:15 AM] Code: Start at : [5/28/2015 / 3:40:50 AM] Operation : Read User Code [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... Initial Boot Failed! THIS CHIP SET MUST BE SPD 6531A NOT SUPPORTED BY INFINITY |
05-28-2015, 08:46 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I use normal USB and BootKey - never got a problem. And yes - Inifnity support ALL 6531 phones. |
05-28-2015, 11:37 | #6 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
Pin 1 = Vcc Pin 2 = Usb D- Pin 3 = Usb D+ Pin 4 = Pull Down ( Boot Pin ) Pin 5 = Gnd | |
