MyGSM World | 05-27-2015 17:30 | Karbonn A66 NAND MT6572 blank flash or wrong settings Dear Friends, Karbonn A66 NAND MT6572 Read Info Ok! But Can't Format Even I Tried With P1,P2,P3,P4 ExBoot.
Operation : Check / Read Info [ v1.21 ] With NAND Init Mode Default (Autodetect) Code:
Wait for phone...
Phone found! [ 170 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8B00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 000100BC009000550056000100BC0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0097 , [Gigadevice] GD5F4GQ4UAYIG
[NAND] : FLASH_DIE : 0001 00BC 0090 0055 0056 0001 00BC
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect done [31]
[AP] : Initial info read Ok!
Done!
Elapsed: 00:01:11
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.21 ] Code:
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8B00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Error read initial info , blank flash or wrong settings?
Operation Failed
Elapsed: 00:00:05
Operation : Check / Read Info [ v1.21 ] With NAND Init Mode P1,P2,P3,P4 ExBoot. Code:
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8B00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
NAND : Structure detect failed [1F]! Send report to support!
Info read not done :( Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:45
Reconnect Power/Cable! |
