12-04-2014, 14:07 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn Sparkle V (androidone), Info read not done Code: Operation : Check / Read Info [ v1.07 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1E0387109 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1E0387109 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read Flash [ v1.07 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1E0387109 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1E0387109 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read error :( Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
12-04-2014, 16:43 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello! Can you test same phone with v1.06? Maybe I missed something... P.s. : according this post : http://forum.gsmhosting.com/vbb/f296...world-1888486/ Not miss. There is exist factory fw for this phone? Will be great. |
12-04-2014, 17:39 | #4 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Here Is Test Report With V1.06. Chinese Miracle II [MTK module] v 1.06 Code: Operation : Check / Read Info [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 202 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1E0387109 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1E0387109 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 202 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1E0387109 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1E0387109 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read error :( Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! | |
12-04-2014, 18:37 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | @JorgeVla , got the file, thanks! Seems as fresh eMMC phone also require some tune up. From next version will be supported. |
The Following User Says Thank You to Dzirt For This Useful Post: |
12-22-2014, 18:00 | #7 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Still Not Work With Version 1.08 Operation : Check / Read Info [ v1.08 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Error : Correct DA sequence not found for target! Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
12-22-2014, 18:02 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Because you need change exe in current CM2MTK folder to new one, not start it from rar file |
12-22-2014, 18:11 | #9 (permalink) | |
You Are Right. Now Here Is Log. Operation : Check / Read Info [ v1.08 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1E0387109 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1E0387109 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND/eMMC init Mode Done! Elapsed: 00:00:38 Reconnect Power/Cable! Where Is This Settings ? | |
12-22-2014, 18:47 | #11 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, Still Not Read After Settings. Operation : Check / Read Info [ v1.08 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1E0387109 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1E0387109 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND/eMMC init Mode Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
04-02-2015, 11:40 | #13 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | is there any progress because i have same set i working fine i only want to read its firmware because it update to lollypop Code: Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A2E01A9189 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2E01A9189 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A2E01A9189 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2E01A9189 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A2E01A9189 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2E01A9189 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v4.2 on BBID : 0xFF Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! |
10-21-2015, 21:39 | #14 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, Still Not Work With New Version. Operation : Check / Read Info [ v1.34 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040503A1015681FD DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A1015681FD [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
