04-11-2021, 06:02 | #1 (permalink) |
Insane Poster Join Date: Jun 2020 Location: Earth Age: 30
Member: 2958962 Status: Offline Thanks Meter: 28 | kaspersky Always detect Latest MT2 & SP2 As a virus infected file Event: A backup copy of the object was created Component: Application Control Result description: Backup copy created Name: UDSangerousObject.Multi.Generic Threat level: High Object path: C:\InfinityBox\CM2SP2 Object name: CM2SP2.exe MD5: 66E3025305BF8A5F6B628BAD24BB69C0 |
04-11-2021, 06:52 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: philippines
Member: 773960 Status: Offline Thanks Meter: 529 | never use kaspersky... if your a technician.... you cannot do your job properly.... just use win 10 64bit.. and turn off av when using..or put that in the inclusion of av.. |
The Following User Says Thank You to sigma xi For This Useful Post: |
04-11-2021, 06:55 | #4 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | A technician can not work properly if he use an antivirus Sent from my SM-G610F using Tapatalk |
The Following 2 Users Say Thank You to zoiya For This Useful Post: |
04-11-2021, 08:59 | #5 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Offline Thanks Meter: 480 | Quote:
Best Regards | Bayaaa | |
The Following User Says Thank You to eyobaaa For This Useful Post: |
04-11-2021, 09:03 | #6 (permalink) | |
04-11-2021, 10:24 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
It gives FALSE alarm. You should disable antivirus or add Infinity software to exclusion list | |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
04-11-2021, 10:26 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | When your phone will be killed during flashing because your antivirus tool block boot or preloader file (that you forgot to add to exclusion) and flashing will be interrupted - you will see the real power of your installed antivirus tool. |
04-12-2021, 20:19 | #13 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | An every AV program req some brain in head, if someone forgot to put CM in exclusion list is this Kaspersky fault?? I'm using KIS about ten years and I can say it's the best AV in the world! ))) |
