Old 01-31-2008, 12:28   #1 (permalink)
fastlink Jogja's Avatar
Member: 192822
Thanks Meter: 18
how to flash panasonic X200
hi.. anyone can explain clearly how to flash panasonic x200 using infinity box? i have X200 hang at startup logo. when i try to flash, software didnt respond ( cannot connect to phone ). cable is ok. what i miss? or maybe there's other trick to repair my X200without flashing it?
thanks..
fastlink
Old 01-31-2008, 14:23   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
There is no any tricks. Ordinary T191 cable.
Check phone connector, it may be damaged. Also if phone hang you must open phone and check phone hardware !
Old 02-08-2008, 20:28   #3 (permalink)
Member: 192822
Thanks Meter: 18
ok. i will check phone hardware again.
one more question : can i use direct usb to com for connecting phone? i have cable T190 usb to vcom using similiar dku5 driver but still can't read phone. or for this cable model we only can use RJ45 cable?
thanks
fastlink
Old 02-08-2008, 21:23   #4 (permalink)
Member: 130995
Hello,
I think you can use any cable that you have, I don't know any reason that phone can't connect depends on cable type.
One thing: be sure that connector inserted into phone completely, probably need to cut rubber around cable connector metal pin to make it inserted into phone completely.
Old 02-09-2008, 20:53   #5 (permalink)
Member: 192822
Thanks Meter: 18
today i opened phone to check phone hardware. and phone completly in good condition, did'nt indicate was water damage or fall to ground, etc.
i call the owner and he said his phone suddenly hang at start up without any accident.
i try to rehot flash ic and CPU infineon PMB 7850 E still no result.
i try to remove backup battery to because sometimes phone will hang too in start up if back up battery failed. but still no result
so i think this is software problem. today i received custsomers phone which want to unlock C261 tracfone and everything is okey. i unlocked successly. so cable is not problem, i have two good cable for T190.
any idea?
if i want to connect phone in test mode to make RESET, is naturaly if phone just white screen on lcd with back light appear? still no connection in that mode.
help me...
thanks
fastlink
h
Old 02-09-2008, 21:14   #6 (permalink)
Member: 130995
Hello,
I can see the only one reason that phone can't be connected: phone connector is damaged ot some protection circuits is damaged. Also probably other hardware faults can be a reason.
How to flash Panasonic X70???? Maurone Infinity-Box 33 10-22-2009 05:36
how to flash panasonic x500.. titan_wonder Infinity-Box 5 06-22-2007 05:33
How to flash Panasonic VS3? venki.bg Panasonic 3 02-04-2007 19:06
How to flash Panasonic GD 87? Cermis Panasonic 3 11-25-2003 13:26
Page generated in 0.22855 seconds with 9 queries
