07-22-2008, 09:21 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: sri lanka/thailand/maldives Age: 44
Member: 283763 Status: Offline Thanks Meter: 102 | ke850 ***** unlocking problem i already unlock ke 850 using infinity , then write original imei but still lock . pl help me . what to do thanks |
09-20-2008, 07:35 | #3 (permalink) |
Banned Join Date: Jun 2008 Location: PAKISTAN Age: 34
Member: 798117 Status: Offline Thanks Meter: 267 | COM11 [VCP1] selected Device: LG-KE850 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-sta_20080920-104637.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-sta2_20080920-104640.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-sec_35030526000000100_20080920-104643.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_35030526000000100_20080920-104644.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01D0 Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 37 sec then write original imei but still lock . sir but still code any another solution |
09-20-2008, 08:05 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: PK, Remote Unlocking Services,
Member: 558087 Status: Offline Sonork: 100.1579413 Thanks Meter: 332 | try this reset code , 2945 hash*hash , My kg800 same problem , but i enter this code , phone will be ok , Br, , Noman Gujjar , |
ke850 ***** unlocked succesfull ok but show insert right sim card | genci titi 2002 | Infinity-Box | 1 | 08-25-2009 17:25 |
KE850 ***** Date Problem | doke616 | LG | 5 | 04-10-2008 10:38 |
lg ***** unlock problem | aligsmpak | FuriousGold | 2 | 11-26-2007 17:05 |
KE850 ***** Unlock Problem | karabey | ULT PRO | 1 | 08-29-2007 12:28 |
Lg Ke850 ***** Unlocking | ferre | LG | 4 | 07-29-2007 14:28 |
