Old 06-23-2008, 13:07   #1 (permalink)
Member: 102129
Thanks Meter: 3
KE970 flash problem
I'm having problems whilst flashing the above model.
All phones are brand new. This has only started recently.
Phone works okay, unlock okay, phone works fine.
Flash phone to debrand it and the phone is now locked. Re-unlock phone and now the phone will not switch on. Re-flash it and phone will switch on but is locked again. Unlock it again and once again the phone will not switch on again.
Each time the procedure for flashing/unlocking works fine without any errors in the logs or during the procedure. Eventually on last Friday it flashed/unlocked with out relocking/not switching on. I'm not sure why it work that time but it just did.
Today I have anothe KE970 (brand new out of the box) and it is doing the same thing, any ideas?
Old 06-23-2008, 13:23   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, post here unlock operation log so we can check what is the problem.
Also, please, make this:
1. read eeprom from working phone
2. make unlock
3. read eeprom again
send both eeporm files (before and after unlock) to [email protected] so we can check what is the problem
Also you can try to download previous "Pana01" software from software/updates/archive folder and try to unlock phone with previous version.
Let's see results
Old 06-23-2008, 15:13   #3 (permalink)
Member: 189097
Thanks Meter: 40
Rehot Cpu And Formatted By Spiderman Box
Old 06-23-2008, 15:43   #4 (permalink)
Member: 102129
Thanks Meter: 3
There is nothing wrong with the hardware, it is a brand new phone and will work perfectly well if reflashed and left locked on T-Mobile. The problem is whe I unlock it.
Old 06-23-2008, 17:05   #5 (permalink)
Member: 130995
@naveen_naveen
You must think before write. Please, do so next time...
Old 06-24-2008, 13:46   #6 (permalink)
Member: 102129
Thanks Meter: 3
Having tried both the Apr & Aug 2007 firmwares located in support and
flashed them both several times without success, today I downloaded the May 2007 firmware and that has worked without relocking the phone to its original network.
I'm not sure why this has happened but it seems that when the phone was unlocked, even by using codes as opposed to direct unlock, this did something to the phone to upset it, I even wrote the IMEI again but it just wouldn't boot properly. Then reflashing somehow undid the unlock procedure.
Anyway, May 2007 firmware resolved the issue.
The Following User Says Thank You to Road_Hog For This Useful Post:
Old 06-24-2008, 20:32   #7 (permalink)
Member: 130995
Thanks a lot for experience, hope it will be useful for other people !
Old 06-25-2008, 16:48   #8 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 76
Same Problem, Tried It w/o Eeprom Repair.
GSM99
Old 06-25-2008, 16:58   #9 (permalink)
Member: 130995
Did you tried to follow method that was described in current thread ?
Old 06-25-2008, 21:38   #10 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 76
Yes; All Tried, But No Results
Also The Handset Is In My Hand Till Now (3 Days)
GSM99
Old 06-25-2008, 22:04   #11 (permalink)
Member: 130995
Hello,
Please, make detailed explanation of your "the same" problem so we will be able to think how to solve it.
Old 06-26-2008, 09:56   #12 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 76
The Phone Hang On Startup Logo (KE970).
I Tried Many Time To Flash It With Different Frw In Support Area, Repair Eeprom Too.
Plz Don't Say HW Problem, Cos I Verified The Phone HW, All It's Ok.
GSM99
Old 06-26-2008, 10:31   #13 (permalink)
Member: 130995
Ok, I did not say about "hardware problems", I just make you an offer: reball flash and CPU.
Also, if you want to get real advice it is good idea to explain the problem so detailed as possible, explain here phone history and more details but do not write zero explanation like "same problem" !
Old 06-26-2008, 21:13   #14 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 76
Thks For Your "Offer" Bro;
And Your Advice Too, I Think Well You Are A Programmer so it is enough for you only one word To Know The Real Problem, This Is A Reason To Write "Zero Explanation".
Anyway The Problem Are Solved.
Thks Again
GSM99
Old 06-26-2008, 21:51   #15 (permalink)
Member: 130995
I am very glad to hear that your problem is solved.
Please, next time post here solution instead of words "problem solved" because I am absolutel sure that nobody interested in words like "I solve my problem" but everybody interested in ways to solve the problem.
Good luck !
LG-KE970 Flashing Problem JaY'Treze Infinity-Box 17 12-03-2008 17:37
LG KE970 Flash Problem imran_qasim Infinity-Box 3 08-29-2008 19:20
Ke970 Flash Problem Help Pls kaaniletisim VygisToolbox 3 12-15-2007 09:52
Ke970 Flashing Problem hans salim ULT PRO 4 11-21-2007 17:10
KE970 flashing problem UnlockBR FuriousGold 2 11-02-2007 07:36
Page generated in 0.23747 seconds with 9 queries
