04-04-2018, 11:27 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: PAKISTAN Age: 34
Member: 1843249 Status: Offline Sonork: 100.1674945 Thanks Meter: 26 | Kechaoda K115 with Dual Sim MT6261 Flash file Here 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 9C374A03B9B8D029BC93D79F454EC23F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : TIANQIN61D_BTD_11C_PCB01_gprs_MT6261_S00.T10B_KECH AODA_QARI_170713.bin FileVersion : T10B_KECHAODA_QARI_170713 Saved to : C:\InfinityBox\CM2MTK\Read_out\TIANQIN61D_BTD_11C_ PCB01_gprs_MT6261_S00.T10B_KECHAODA_QARI_170713.bi n Done! Elapsed: 00:00:12 Reconnect Power/Cable! http://https://mega.nz/#!tl8CjZ6S!7S...f0J8vJDdGJfkBk Pass=gsmtaha1 |
04-05-2018, 09:23 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
