08-11-2008, 12:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: on a different planet
Member: 228253 Status: Offline Thanks Meter: 22 | kf 600 Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.51 S/N: 1D87:010F Wait... Current model: LG-KF600 Ready COM3 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 61 sec COM3 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: not locked or unknown eeprom Check memory Failed Finished, Remove/Install battery now ! Time used: 42 sec COM3 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: not locked or unknown eeprom Check memory Failed Finished, Remove/Install battery now ! Time used: 41 sec COM3 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: not locked or unknown eeprom Check memory Failed Finished, Remove/Install battery now ! Time used: 74 sec COM3 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes Finished, Remove/Install battery now ! Time used: 41 sec |
08-14-2008, 07:42 | #4 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Here is an instruction how to get cable/pinout information: 1. run Infinity-Box Shell 2. select required model 3. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
kf 600 | stevefillby | FuriousGold | 1 | 02-25-2009 13:05 |
can t unlock kf 600 and kf 510 | gurbuz | LG Hardware Repair | 0 | 01-08-2009 17:56 |
kf 600 cant be unlocked by both method plz help | mobile_mania | Infinity-Box | 4 | 12-24-2008 08:09 |
KF 600 flash files needed | Faheem Anjum | FuriousGold | 1 | 12-03-2008 12:42 |
KF 600 unlock | lafuente | ULT PRO | 1 | 07-21-2008 08:53 |
