06-14-2011, 07:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | Kg 195 hang on logo new exe not work.infinity chek this bug. run chinese mirecle exe selct 6228nand and make whole flash chip after this change imei but with new exe problem with formating whole flash chip with new exe soft make backup long time 40 minute after making backup again start for backup more 40 minate please chek this bugs and clear next update.:d |
06-15-2011, 05:22 | #4 (permalink) |
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | here is log after reading backup process fail i chek cable working good. Code: COM4 [VCP0] selected module v3.31 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6226:8A02:8A01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6226:8A02:8A01 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7332SA00-001-R1D detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1D.BIN project-id: 7S7332SA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: D6739D29E1D48CF995BE673C52B8CF8C warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done ==================== New firmware found (v.3.31, database date: 29.05.2011): ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1D.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\Program Files\INFINITY\ChineseMiracle\ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1D__fullflash_20110613-231009.B0M.bin area size: 64Mb number of areas/bytes to read: 1:04000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: can not read memory: 0FAA:S_FT_READBACK_FAIL can not read memory, errorcode: 0FAA it may be problem with current operation Format... 00000000-03FFFFFF... error: can not format: 0FAB:S_FT_FORMAT_FAIL error: last error: 0FAB:S_FT_FORMAT_FAIL Disconnect... done Finished, time used: 30 min 53 sec Remove/Install battery now ! |
06-15-2011, 05:34 | #5 (permalink) |
Freak Poster Join Date: Feb 2011 Location: JUMP JUMP JUMP
Member: 1513644 Status: Offline Thanks Meter: 51 | hi do not backup, had the same problem yesterday did give format fail 1st , but in the next attempt it did format , no bug also in new version regards Jumper |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
