05-19-2009, 16:36 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: (¯`-._UK_.-´¯) Age: 43
Member: 727518 Status: Offline Sonork: 100:1588024 Thanks Meter: 502 | Need urgent help!!! China samsung i900!!! software version: 1.17 cable type: 1x20 (L20A) platform: MT: MT62xx (autodetect) searching adapter at COM7... adapter found, version: 2000 pins: 20, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: error: boot initialization step #2 failed: 19200 fixed error: boot initialization step #2 failed: 00 error: boot initialization step #2 failed: 00 |
05-19-2009, 21:57 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can't you open phone and check or try *#0044# code? dont forget to press green (send) button after that, if you see "Language set: English"- you can be sure that this phone is mt62xx CPU based |
05-21-2009, 19:39 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if your phone can not be powered from box power- no point to search pinout. you must modify your main infinity box to increase output voltage. for this you need to remove Diode. procedure described in Pinfinder User Manual (with pictures) please do this and reply |
05-23-2009, 13:57 | #8 (permalink) |
Member: 727518 Status: Offline Sonork: 100:1588024 Thanks Meter: 502 | thanx ur info helpful.hare is log.but my problem is now phone is dual sim.1 sim accepted but sim 2 invalid.what i will do plz??? Code: ==== log opened: [22/05/2009 12:35:09] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 5CA1:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [23/05/2009 12:58:19] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] Chinese Miracle v2.82 S/N: 5CA1:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log: [23/05/2009 12:58:46] ==== COM7 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E203:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.82, database date: 15.05.2009): P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111.BIN ver. sw 2: SJZY.P169.1.1.T10.D1111, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111__fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\samsungi900_P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111__fullflash_20090523-132804.B0M Finished, time used: 1799 sec Remove/Install battery now ! ==== log: [23/05/2009 13:29:15] ==== COM7 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E203:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.82, database date: 15.05.2009): P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111.BIN ver. sw 2: SJZY.P169.1.1.T10.D1111, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\samsungi900_P169_SJZY_PCB01_GPRS_MT6225_S00.SJZY_P169_1_1_T10_D1111__ffs_20090523-133442.B0E Finished, time used: 518 sec Remove/Install battery now ! |
05-23-2009, 20:21 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! power On phone and make "read general information" check if both IMEIs are OK. IMEI 135..... can be reason of this problem. change it to valid value |
05-23-2009, 20:54 | #10 (permalink) |
Member: 727518 Status: Offline Sonork: 100:1588024 Thanks Meter: 502 | i got both imei.but 1 imei is starting 35xxxxxxxxxxxxxxx and another imei is 135xxxxxxxxxxxx.i m trying to change 135xxxxx imei but it would not change.always change 35xxxxx imei.can u tell me how can i change this 135xxxxxxxx imei??? |
05-23-2009, 21:47 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! powered On phone, write desired IMEI in IMEI window, select "IMEI #2 for dual sim/mono CPU", IMEI writing mode "Mode-1" should work smooth. if not- post here log |
05-26-2009, 10:39 | #13 (permalink) |
Member: 727518 Status: Offline Sonork: 100:1588024 Thanks Meter: 502 | thanks.my problem solve bro............now both sim working.thanks again Code: Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: LC6225_GEMINI_HW Software version: SJZY.P169.1.1.T10.D1 Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 350448011234561 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei: 359001018037536 verification Ok Finished, time used: 8 sec |
The Following User Says Thank You to GSMHEART For This Useful Post: |
Need urgently help with ORT and i900 | jomafi | QUALCOMM Models (3G) | 3 | 01-12-2010 11:57 |
i900 big problem need urgent help | sameenshah123 | HTC & Smartphones ( WM Without Touch) | 3 | 08-11-2009 18:02 |
i900 big problem need urgent help | sameenshah123 | NSPRO | 4 | 08-03-2009 22:05 |
i900 big problem need urgent help | sameenshah123 | UST Pro II | 4 | 08-02-2009 15:28 |
need urgent help,,p300 samsung | lahoot | Samsung Hardware Repair | 0 | 08-11-2008 12:56 |
