KG 195 Shut off in standby/sleep mode plz plz help me LG KG 195 auto off in standby mode after one or two minutes but when we play games or play adudio or video it is ok and not shut down I format it complete and repaired imie but the same plz help me thanks |
Hello, We never heard about this problem. You can try to flash phone, but if you will see the same problem after flashing you have a reason to check phone hardware. |
Thanks Thanks team buttt i am facing this problem any how i try and post resut |
Till now no way to solve this There is no any solution for this problem in the infinity box i have tried everything flashed the phone after erase and also tried the both formate methods but problem is still the same Team please do something for this problem |
You are wrong ! You did not tried anything ! As I can see you write something without any explanation. I suggest you read more here: https://forum.gsmhosting.com/vbb/f296/kg-195-shut-off-standby-sleep-mode-639873/ Also, did you tried to read current thread name ? Please, post here thread name and then we will see what you talk about, what you have tried and why you say strange words instead of explain problem well. |
disable sleep mode,,, set will be ok. but u have to do it every time you on mobile. because till now this is the solution. |
i also faced with same problem , but its not solved so i give back to phone to customers and yes if we disable sleep mode then mobile will ok but this is not permanent solution !! BR Faisal_Computer |
I have never could solve this problem with SW SO I think it must be a HW problem.Who can find what it will be? |
maybe infinity support/developers can do it cause they are really hardworking guys Br Faisal_Computer |
OK Bro I wish SO and it will be a Great solution for these phones. |
Hello, If you are sure that phone hardware is Ok, I think it may be phone firmware bug (factory firmware has a bug). It's just an idea, I do not have any confirmation. You can try to flash phone with another firmware from support area and see results. |
WBR Nawab Sahoo |
