02-26-2009, 11:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: .::AZAD KASHMIR::.
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | kg 276 eeprom problem COM6 [VCP0] selected module v1.62 Device: LG-KG276 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG271 P16 92 V10d XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-static_20090226-150828.B1E.bin loading data... data loaded imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20090226-150829.B1E.bin reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20090226-150836.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Write Done Finished, time used: 412 sec Remove/Install battery now ! |
03-02-2009, 16:47 | #5 (permalink) |
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | yes sir i make unlock method #2 and then reset setting eeprom is ok signal is ok but another problem full charged battery phone show low battery and out of batter after write eeprom no battery problem? |
03-04-2009, 21:53 | #7 (permalink) |
Insane Poster Join Date: Mar 2009 Location: karachi
Member: 986684 Status: Offline Sonork: lock Thanks Meter: 11 | hi dear i i makeing is lote lg brand set but sorry i dont nderstand waht there is it.s a problm please again i repet you if have your cellphone signal trobil so you can make it's try full flish frist munall code 2945#*# another singal is trobil so you chang is rf if will be trobill when flish is infrdy box thankx |
03-04-2009, 21:56 | #8 (permalink) |
Member: 986684 Status: Offline Sonork: lock Thanks Meter: 11 | hi dear youdont know it;s all mosel is samebord here for exampill kg 270 276 so you frist flish is munalwhen i send allthe matha don;t warrey be brother thankx |
01-26-2011, 06:16 | #11 (permalink) |
No Life Poster Join Date: Feb 2008 Location: +919304287474 Age: 41
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | COM2 [VCP3] selected module v1.78 Device: LG-KG276 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL CIS Open KG276 P16 07 V10b XXX-XX AUG 13 2007 +0 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-static_20110126-060502.B1E.bin loading data... data loaded imei: 0Q@00¶200Ì0P0œ@00 reading eeprom-security_0Q@00¶200Ì0P0œ@00... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-security_0Q@00¶200Ì0P0œ@00_20110126-060503.B1E.bin reading eeprom-complete_0Q@00¶200Ì0P0œ@00... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_0Q@00¶200Ì0P0œ@00_20110126-060510.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 32 sec Remove/Install battery now ! my problemes solved thanks infinitiy team |
The Following User Says Thank You to DHEERAJ_SHARMA For This Useful Post: |
01-26-2011, 08:21 | #13 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
kg 276 sim card error | madho | LG Hardware Repair | 4 | 10-13-2011 07:25 |
kg 276 problem | deepaksawdia | Infinity-Box | 2 | 08-15-2009 20:39 |
KG 270 eeprom problem ? | aminnovelty | Infinity-Box | 1 | 08-11-2009 22:53 |
kg 276 | mediapeople | Infinity-Box | 0 | 07-18-2008 12:12 |
KG 276 CANT BOOT ON UFS+hwk | kashif-ch | LG | 3 | 05-14-2008 10:40 |
