KG130 blue sreen after flash Hello Infinity Support! I had LG KG130 with version: ***-XXV10fEURKG130P40 I flashed it with version: ***-XXV10a07KG130P40 and after that my phone sreen apear blue. I can make or recive calls but nothing hapens on the sreen. I've searched this version on support site adn I didn't find it... So what do I have to do to resolve this problem? Here is log after first flashing: Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.30 S/N: 373B:010F Wait... Current device: LG B2000 Done Current device: LG KG130 Loading file v.02... KG130P40-07-v10a_***-XX_MAY-14-2007_code[1].B1M.bin loaded Loading file v.02... KG130P40-07-v10a_***-XX_MAY-14-2007_alchemy[1].B1P.bin loaded Testing COM1 at 921600... COM1 [Serial0] selected error: can't open COM1 COM8 ready Testing COM8 at 921600... COM8 [VCP0] selected Device: LG KG130 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 3553110***xx024 current otp imei: 3553110***xx024 file saved: C:\Documents and Settings\gR\Desktop\eeprom_3553110***xx024_LG KG130_20080709-170952.B1E.bin ....... version: ***-XXV10fEURKG130P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 576 sec Remove/Install battery now ! |
flash with latast version |
hi give me result ? |
what was the purpose behind flashing was it dead or just for language changing ? |
I only wanted to change lang as usualy. I flashed it with 10c and 10d version - no result |
Infinity Support! Can you answer to me something? I must to know: shell I wait or buy new phone? |
If not help- backup original eeprom and write eeprom from support. |
@gr_from Any results after advice given by respected Mr. ..::alexis::.. ? |
no results. same problem. with other boxes same situation. need 10f version but where can get this one? |
...and I made this thread ONLY after I tryed ALL versions on support. only once on the screen apeared something normal. But the phone hang up and after that (no matter what I did) sreen is blue again. And than I had made this thread. |
Hello, Did you tried to use repair_eeprom and repair_ffs files ? |
Hello, in fact it\'s not so important, you can use ffs files like eeprom files. |
Maybe try to open phone and check what version must be in phone(label on flash IC) Because for example C1100 have two different firmmwares type- 1xx and 2xx And when you write 1xx to phone with 2xx you get working phone with blue screen. |
I'll post results tommorow. thanks |
