Old 08-06-2008, 14:07   #1 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
Lg Kp220 Problem
I have a LG KP220 which is come to me in fault only startup logo comes and hang.i try to format with the help of pinfinder pins selected manulay but not work. i try to find i select cable "L18B" and "cpu independent(autodetect)algorithm" here is logs
software version: 1.14
cable type: 1x18 (L18B)
platform: CPU independent (autodetect) algorithm
searching adapter at COM7...
adapter found, version: 2000
pins: 18, plain
power cycles: 1
activation cycles: 5
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Phone should be Powered-On !
Power-On phone now and press "Ok"
Be sure that phone is not in sleep mode during pinout detection !
Press any phone key from time to time to wake-up phone.
detecting pins...
detected baudrate: 115200
result: Rx:16 Tx:14
time required: 12 sec
Power On !
it detects pinouts diffrents from given in soft.after detecting i format it but not connected.so plz tell me how i format it.
Old 08-07-2008, 14:36   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Double check that phone connector is Ok.
If you want to detect pinout for KP220 you must select AD CPU type.
LG KP220 searching network problem ribka LG Hardware Repair 2 05-03-2012 15:44
lg kp220 kypad problem chalia LG Hardware Repair 10 01-05-2011 14:21
LG KP220 Hang on LG Logo Qaisar Mahmood Infinity-Box 7 04-26-2010 19:11
LG KP220 power off problem zeerik Infinity-Box 4 10-21-2009 22:46
lg kp220 kypad problem chalia LG Hardware Repair 3 09-09-2009 14:53
Page generated in 0.14805 seconds with 9 queries
