Old 11-03-2007, 15:40   #1 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
$## Need Pinout for TREND T300 ##$
hi all
i need pinout for Trend T300 many thanks
1x8
Faisal_Computer
Old 11-04-2007, 05:54   #2 (permalink)
Member: 151871
need it Badly
Faisal_Computer
Old 11-05-2007, 07:01   #3 (permalink)
Member: 151871
waiting for reply
Faisal_Computer
Old 11-06-2007, 19:55   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Dear Friend,
2 days gone. 1x8 pins connector. 8 - 1 (gnd) - 1 (charge) = 6 rest pins can be used as Rx/Tx. I think you can find pinout by yourseld faster than wait for reply.
Please, don't forgte to post your found pinout here.
Here is detailed instruction for you if you have lost it:
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 11-07-2007, 06:20   #5 (permalink)
Member: 151871
Brother many thanks for reply !!
i do mostly all Things but can't get pinouts and Problem is Mobile Was Gone .. so that why i can't do any thing else and i am asking for pinout cause for next time if i got any TREND T300 i have pinouts hope you understand
br
Faisal_Computer
Old 11-07-2007, 11:23   #6 (permalink)
Member: 130995
Hello,
If you have tried all connector pins but no luck this mens that Rx/Tx point should be located on PCB, so it was need to open phone and try to find RXD and TXD points directly at phone PCB.
Old 11-08-2007, 06:14   #7 (permalink)
Member: 151871
Brother i tried !!
no luck
Faisal_Computer
Old 11-08-2007, 11:44   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
pinout must be somewhere!! 8 pin is not much to try brute force.
only 56 combinations. solder all conacts and try all possible combinations
Old 12-06-2007, 12:39   #9 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Another HINT
new Trend Model T786 comes to my hand some days ago . Phone donot have MTK CPU inside
Old 12-06-2007, 12:51   #10 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Ok
I got the OK phone in my Hands
Processor is MT6228 Nand
Problem is that Chinese Miracle not fully supports this CPU
Only Safe Formatting Works on this CPU
Full Formatting never helps .
so Safe Formatting is OK
But when i read FULL Flash
COM4 [VCP0] selected
Device: Autodetect 6228 NAND
Checking data, wait...
Action: read NAND flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6228:8A02:8A02]...
chip: 0031:0000:0101
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
version: 3.1
NAND id: ADF1801D
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00AD:00F10080001D [08400000]
NOR chip is not installed
Initialize Done
Set baud...
921600
Set baud Done
Identification...
reading...
detecting structure...
converting data...
done 0x00080000 bytes
identification#1 protocol ver: 04
ver. sw1: HEDY28_06A_PCB04_GPRS_MT6228_S02.MAUI_06A_06_36_M7 8_VT_1_38.BIN
ver. sw2: MAUI.06A.06.36.M78.VT.1.38
ffs offset/size: 02000000/06000000
id-page Ok
nfi area detection finished: Ok
identification#1 structure: 2nd [standard] (or higher) generation
reading...
error: unexpected answer:
warning: probably errors exist during flash read operation
Finished, time used: 40 sec
Remove/Install battery now !
I also Recieves many MT6228 CPU like ON OFF Problem
keep restarting
Software shows Full Formatting OK but phone still have problems
& some phone i recieve of thsi CPU have SIM Restart Problem means After we SIM in Phone it restarts as it accepts SIM
so this Phone can be 100% Ok by Safe Formatting
so Safe formatting is OK & nothing else working
Thanks
Aamir Zia
Old 12-06-2007, 13:07   #11 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
china china china
i'm afraid i sleep and after wake up see chiesss melmel
regards'
melmel
Old 12-06-2007, 18:05   #12 (permalink)
Member: 130995
@Aamir_Zia
what cable you have used ? Is it was FTDI-based unibox or other Prolific-cables ?
Old 02-15-2008, 21:58   #13 (permalink)
Member: 50103
Thanks Meter: 3
hi guys.. sorry my question is not related to the topic.. but
1. can someone point me the way from where i can get all the flash files for TREND mobile phones?
2. does anyone know how can we modify those flash files? so we can replace the start-up logo of them and the default ringtones? because each time i flash trend phones with chinese flash.. i get chinese ringtones and videos in it.. i want to modify those files, to put ringtones and videos of my choice.
please if some one can help me in it.
thanks
bbye
Old 02-15-2008, 22:36   #14 (permalink)
Member: 148515
hello!
best of all i would advice to find same phone with needed languages / pictures/ music and read out flash.
later you can use it to flash your phones
we dont have any soft to edit/add/remove them
Old 04-30-2009, 10:07   #15 (permalink)
gsm_dreemy's Avatar
Member: 905296
Sonork: 100.1591442
Thanks Meter: 336
i need flash file for Trend T300 many thanks urgent
Page generated in 0.67472 seconds with 8 queries
