01-01-2009, 12:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan (Layyah) Punjab Age: 37
Member: 453862 Status: Offline Thanks Meter: 53 | KG200 Hang on startup KG 200 Came in dead position i formated it full but not ON ,than i format whole flash chip and flashed new flash file now mobile power on and Hang on LG and not power OFF by key. Plz Guide me what to do Thanks |
The Following User Says Thank You to Tahir Riaz For This Useful Post: |
01-01-2009, 12:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | format phone (whole flash chip) using chinese exe. before doing that select in settings 6228,6229,6230 nand. tested solution .plz try now and post result. |
01-01-2009, 12:55 | #4 (permalink) |
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | have u tried the following setting marked red?see in pic http://imagehoster.us/uploads/d54fc389f2.bmp |
01-01-2009, 13:35 | #10 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
flash again, after that flash eeprom to, ( tick), format FFS during write (reset to default value), after that try power on the phone, iff the phone can't power on flash again eeprom with deference eeprom in support, don't forget to repair imei regards notgood | |
01-02-2009, 22:15 | #11 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | @Tahir Riaz read this: http://forum.gsmhosting.com/vbb/show...24&postcount=2 follow this advice and post here operation log so we can see what you have tried to do. Waiting for results... |
01-03-2009, 13:01 | #12 (permalink) |
Member: 453862 Status: Offline Thanks Meter: 53 | Here are logs Plz guide what can i do? COM4 [VCP0] selected Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: erase flash chip Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 high speed boot enabled CPU: MT6226MA detected chip: 0031:6CC11AA boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.020B loader: 3.748.0 NAND id: 98F08095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0200 NOR: 0098:004900000000 [01000000] NAND: 0098:00F000800095 [04200000] Initialize Done Set baud... 921600 Set baud Done Identification... reading structure area... detecting structure... warning: incorrect bootloader header: 94344B99033BDA15ADB77E1DB3BF24ED nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Write... formatting... .................................................. .................................................. Write Done Finished, time used: 58 sec Remove/Install battery now ! |
01-04-2009, 09:22 | #14 (permalink) |
Member: 453862 Status: Offline Thanks Meter: 53 | Sir mobile came in dead position i do following 1.full format the phone same 2.full flashed with file downloaded from support same 3.format whole flash chip and flash again mobile on but still on lg logo 4.format nand in chinies miracle with(whole flash chip) again dead again format and flash then still on lg format nand again dead |
01-04-2009, 12:58 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you have made NAND format you must press and hold phone "Power" button during long time to make phone powered-on. If phone still can not power-ob well after all format types and after flashing you must check phone hardware. |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
k700 hang on startup when with sim solution! | dennis2003 | Sony Ericsson | 20 | 08-14-2010 13:01 |
medion md95100 hang on startup** | infogsm | Various | 3 | 01-05-2006 01:58 |
samsung x100 hang on startup | HUM | Samsung Hardware Repair | 5 | 08-23-2005 12:58 |
***e810 hang on startup*** | infogsm | SYSOL Platform | 1 | 08-18-2005 18:18 |
**myx1 twin hang on startup (!)*** | infogsm | ARM9 BASED M62 / M62+ | 5 | 06-06-2005 08:18 |
