KG275 Restart after flash with infinity Hi, I got LG KG275, it was turned off when I try to go inbox of messsag, and after flash with infinity now the phone is not turning on, when i push power I just see lg only and going off. Here is the log: Flashed with: KG270P16-07-V10h-000-00-JAN-24-2008_firmware.B1M KG270P16-07-V10h-000-00-JAN-24-2008_lp.B1P KG270P16-07-V10h-000-00-JAN-24-2008_file_system.B1S COM21 [VCP0] selected module v1.66 Device: LG-KG275 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL PT TMN KG275 P16 FL 351 V10b 268-06 MAY 29 2007 +2 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-static_20090726-150705.B1E.bin loading data... data loaded imei: 35858201814537000 reading eeprom-security_35858201814537000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-security_35858201814537000_20090726-150706.B1E.bin reading eeprom-complete_35858201814537000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_35858201814537000_20090726-150708.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 166 sec Remove/Install battery now ! |
Hello, 1. try to use another files set for flashing 2. make unlock my "method #2" |
KG275 restart after flash Quote:
WARNING ! You have exceeded daily download limit, please try again tommorrow. Please do not use any download accelerator software to avoid problems with download limits. My user is : 082XXXX Please help. |
Flash only with eeprom 1000% tested ur problem will be solved |
@Unicom Please do not use any download accelerator software to avoid problems with download limits. Also, you can download files from another support area mirror. |
