08-19-2008, 19:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 43
Member: 389002 Status: Offline Thanks Meter: 82 | kg275 unlock error solution.. when??? status: no network : can't write repair eeprom and here is the logs...... COM8 [VCP0] selected Device: LG-KG275 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL PL ERA KG275 P16 FL 48 V10b 260-02 OCT 26 2007 +1 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-sta_20080820-011957.B1E.bin loading data... data loaded imei: 35858201866542700 reading [eeprom-sec_35858201866542700]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-sec_35858201866542700_20080820-011959.B1E.bin reading [eeprom-complete_35858201866542700]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_35858201866542700_20080820-012002.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Eeprom Writing: Eeprom repair write error [007F2000]... error: write failed[007F0000] Write Failed Finished, Remove/Install battery now ! Time used: 29 sec |
08-31-2008, 20:12 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @all who has problems with kg27x unlock/flash: Hello, Please, try to use updated software: http://www.infinity-box.com/download...na01_v1.52.rar if it was problem with unlock (or eeprom write) and software freez at 12% you need to write original eeprom back first and make unlock again. If you do not have original eepom backup and phone is damaged: use repair_eeprom files from support area and make unlock by different methods. We are waiting for your results. |
09-01-2008, 16:58 | #8 (permalink) |
Member: 389002 Status: Offline Thanks Meter: 82 | i got problem the phone become auto shot off i try twice but the same problem here is the log COM12 [VCP0] selected Device: LG-KG275 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-sta_20080902-005117.B1E.bin loading data... data loaded imei: 35858............. reading [eeprom-sec_35858101234757800]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-sec_35858101234757800_20080902-005121.B1E.bin reading [eeprom-complete_35858101234757800]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_35858101234757800_20080902-005124.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 165 sec i dont have the backup eeprom i download on the support what do you think is the problem??? |
09-01-2008, 17:26 | #9 (permalink) |
Member: 389002 Status: Offline Thanks Meter: 82 | i got it sir!! the problem is i unlock with read code solution is you need to unlock with direct unlock method #2 COM12 [VCP0] selected Device: LG-KG275 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL CIS Open KG270 KG270 P16 07 V10h XXX-XX JAN 24 2008 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-sta_20080902-004433.B1E.bin loading data... data loaded imei: 35858 reading [eeprom-sec_35858]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-sec_35858101234757800_20080902-004441.B1E.bin reading [eeprom-complete_35858101234757800]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_35858101234757800_20080902-004443.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 58305998 Finished, Remove/Install battery now ! |
The Following 2 Users Say Thank You to eljhay For This Useful Post: |
09-02-2008, 12:35 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Lg kg275 unlocking error | afridi4all | Infinity-Box | 8 | 10-21-2008 09:00 |
lg kg275 unlocking error... | reimon23 | Infinity-Box | 19 | 08-31-2008 20:20 |
kg275 unlock error | Cont@ct Service | FuriousGold | 3 | 08-02-2008 20:34 |
KG275 unlock error ... ! | llcoolr | FuriousGold | 5 | 11-06-2007 22:35 |
*****lg U81xx with unlock error solution**** | infogsm | Redbox | 2 | 01-04-2005 17:00 |
