12-21-2009, 07:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | kg300 dead after whole chip format method COM27 [VCP1] selected module v2.99 Device: LG-KG300 Checking data, wait... advanced flash detection enabled Action: write NOR flash write: Firmware KG300P64-ARB-V10d-000-00_DEC-26-2006_ARIMA27_05C_PCB01_GPRS_MT6227_S01[1].7S7312SA00-001-R1B_En_Ru_Fr_Farsi_Ar.A3M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:79C1:AA0E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Fail Finished, time used: 15 sec Remove/Install battery now ! |
12-21-2009, 07:39 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Code: ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Fail Finished, time used: 15 sec Remove/Install battery now ! UR phone is not format........ bro before format phone already damage see ur log .............. Guljee |
12-21-2009, 08:09 | #3 (permalink) | |
Member: 383211 Status: Offline Thanks Meter: 131 | Quote:
COM27 [VCP1] selected module v2.99 Device: LG-KG300 Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:79C1:AA0E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 08 loader: 3.0840.00.00 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 external ram: 00800000 finalize connection... done NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 115200 Set baud Done Identification ... usb bootloader detect... usb bootloader detect (phase #2)... usb bootloader (chip) is absent searching rom info... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... search rom info finished searching rom info... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... reading... search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning error: can't detect ffs/eeprom address Identification Fail Finished, time used: 108 sec Remove/Install battery now ! | |
12-21-2009, 08:26 | #4 (permalink) |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning error: can't detect ffs/eeprom address Identification Fail Finished, time used: 108 sec Remove/Install battery now ! not format again see ur log carefully ur phone hardware damage................ and try flash the phone.... Guljee |
12-21-2009, 10:05 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @pakmobiles Are you sure that software did not asked any questions etc. before stop flash write operation ? If it's just an exit silently - we need to check software to avoid this kind of problem. Please, confirm so we will be able to see what to do. |
12-21-2009, 10:53 | #6 (permalink) |
Freak Poster Join Date: Dec 2003 Location: lagos
Member: 45992 Status: Offline Thanks Meter: 38 | same problem happen to me three days ago,try unlocking phone with no success,so i try formating phone,now phone is dead,cant find flash file in support, please help, phone was given to me to unlock. |
12-21-2009, 11:06 | #7 (permalink) | |
Can you post operation log for flash write operation ? | |
12-21-2009, 15:06 | #11 (permalink) | |
COM9 [VCP1] selected module v2.99 Device: LG-KG300 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware KG300P64-ARB-V10d-000-00_DEC-26-2006_ARIMA27_05C_PCB01_GPRS_MT6227_S01[1].7S7312SA00-001-R1B_En_Ru_Fr_Farsi_Ar.A3M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:79C1:AA0E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Fail Finished, time used: 16 sec Remove/Install battery now ! | |
12-21-2009, 15:20 | #13 (permalink) | |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Quote:
Guljee | |
infinty team plz help me under 12 houarskg200 dead after whole flash chip formate | faisal_fs | Infinity-Box | 8 | 07-06-2009 10:48 |
Lg Kg300 Dead after format | adnanskyland | SpiderMan | 3 | 12-25-2008 06:30 |
s3 dead after whole flash chip-format | zandoo | Infinity-Box | 1 | 11-09-2008 09:41 |
Lg KG300 dead after flash | d14n | Infinity-Box | 43 | 11-04-2007 13:17 |
lg kg300 dead after flesh | dimitron | Infinity-Box | 10 | 03-21-2007 11:46 |
