KG375 Blink after flashen with infinity (phone was dead after unlock with ultpro) Plaese any help ???what flash files can i use to alive the phone and what must i flash (phone was dead after unlock with ultpro) (software version: KG375P16FL-33-V10c-208-10 SEP 11 2007+1 ) KG375 Blink after flashen with infinity (I think wrong flash files) |
Hello, flash phone with the next files: Try #1: KG375P16-FL-33-V10c_208-10_SEP-11-2007+1_firmware.B1M.bin KG375P16-FL-33-V10c_208-10_SEP-11-2007+1_LP.B1P.bin KG375_file_system_dffs_01.B1S.bin KG375_repair_eeprom_01.B1E.bin Try #2: KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_firmware.B1M.bin KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_LP.B1P.bin KG375_file_system_dffs_02.B1S.bin KG375_repair_eeprom_02.B1E.bin pls let me know about results. |
Hello, so as I can understand, after flashing with files set 2 phone is in other condition than before ? Try to charge phone battery (or at least check battery voltage). It may be that you need just charge battery now. |
Thanx for your help (InfinitySupport ) After methode 2 -flashen met Backup eeprom (than s verything ok) |
Hello, As I can understand, phone is alive. Is it right ? If yes, please, tell me exactly what files you have used for repair, it will be useful for other users. Thank you ! |
Firm - KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_firmware.B1M.bin Lang Pack - KG75P16-FL-33-V10c_208-10_SEP-11-2007+2_LP.B1P.bin FFS-2 - KG375_file_system_dffs_02.B1S.bin Eeprom - KG375_repair_eeprom_02.B1E.bin (phone blinken witk logo KG375) after that -Second i flashed with Eeprom - backup_eeprom-sec_35876301536225500_20071217-201638.B1E ***************phone work 100%***************** *****************BACK ALIVE******************** |
hello! thank you for sharing this info! |
i have the same problem.. also killed by ULT i flashed: Firm - KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_firmware.B1M.bin Lang Pack - KG75P16-FL-33-V10c_208-10_SEP-11-2007+2_LP.B1P.bin FFS-2 - KG375_file_system_dffs_02.B1S.bin Eeprom - KG375_repair_eeprom_02.B1E.bin but now the phone is blinking at the kg375 logo when i flash the backup_eeprom_sec file the phone is totaly dead again and not booting.. if i try the 1 option the phone is only blink without logo any solution ? :eek: |
keept playing a while with the phone and selected Unlock method 2 (airtel etc) and now the phone is booting and unlocked :D very good job guys.. this saved me one refund of the phone to the customer :) |
@ssa Thanks for report and new exparience ! @all We are waiting for more eeprom backup files to [email protected] This can helps to make our common file database for better repair results. |
I just revived ma KG375 useing methog "Try #2:" (see above) then after that unlocked useing "direct unlock method #2 (Airtel etc.)". And then rebuild original imei. That's all. Thanks to All |
Quote: Originally Posted by InfinitySupport Hello, As I can understand, phone is alive. Is it right ? If yes, please, tell me exactly what files you have used for repair, it will be useful for other users. Thank you ! -first i flashed with Firm - KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_firmware.B1M.bin Lang Pack - KG75P16-FL-33-V10c_208-10_SEP-11-2007+2_LP.B1P.bin FFS-2 - KG375_file_system_dffs_02.B1S.bin Eeprom - KG375_repair_eeprom_02.B1E.bin (phone blinken witk logo KG375) after that -Second i flashed with Eeprom - backup_eeprom-sec_35876301536225500_20071217-201638.B1E ***************phone work 100%***************** *****************BACK ALIVE******************** very good work yes workd 100% tested by my tank you mounir |
