Old 12-18-2007, 13:55   #1 (permalink)
Mounir's Avatar
Member: 58969
Thanks Meter: 56
KG375 Blink after flashen with infinity (phone was dead after unlock with ultpro)
Plaese any help ???what flash files can i use to alive the phone and what must i flash
(software version: KG375P16FL-33-V10c-208-10 SEP 11 2007+1 )
KG375 Blink after flashen with infinity (I think wrong flash files)
Old 12-18-2007, 14:06   #2 (permalink)
Member: 130995
Thanks Meter: 35,154
Hello,
flash phone with the next files:
Try #1:
KG375P16-FL-33-V10c_208-10_SEP-11-2007+1_firmware.B1M.bin
KG375P16-FL-33-V10c_208-10_SEP-11-2007+1_LP.B1P.bin
KG375_file_system_dffs_01.B1S.bin
KG375_repair_eeprom_01.B1E.bin
Try #2:
KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_firmware.B1M.bin
KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_LP.B1P.bin
KG375_file_system_dffs_02.B1S.bin
KG375_repair_eeprom_02.B1E.bin
pls let me know about results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 12-18-2007, 19:40   #3 (permalink)
Mounir's Avatar
Member: 58969
Thanks Meter: 56
Originally Posted by InfinitySupport View Post
Hello,
Try #1:
Try #2:
methode 1 = phone blink blink
COM14 [VCP0] selected
Device: LG KG375
Checking data, wait...
Action: flash write
Boot...
Press Power button now !
loading...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 00EC:257E
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20071218-172658.B1E.bin
loading data...
data loaded
imei: 35876301359463600
reading [eeprom-sec_35876301359463600]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35876301359463600_20071218-172703.B1E.bin
reading [eeprom-dyn_35876301359463600]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35876301359463600_20071218-172706.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
reset...
done
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Erasing: Language Pack
Writing: Language Pack
Erasing: FFS-2/File system
Writing: FFS-2/File system
Erasing: Eeprom
Writing: Eeprom
Write Done
Finished, Remove/Install battery now !
Time used: 957 sec
methode 2 = blinking with kg375 logo and i can normale scharged
Device: LG KG375
Action: flash write
Boot...
loading...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 00EC:257E
Connecting Done
Check free space...
sw version: ULC2GL ** Vodafone ** KG375 P16 FL 33 V10c 208-10 SEP 11 2007 +1
Check parameters...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20071218-191540.B1E.bin
loading data...
data loaded
imei: 35876301359305900
reading [eeprom-sec_35876301359305900]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35876301359305900_20071218-191616.B1E.bin
reading [eeprom-dyn_35876301359305900]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35876301359305900_20071218-191618.B1E.bin
Check memory...
Check memory Done
Write...
reset...
done
Erasing: Firmware
Writing: Firmware
Erasing: Firmware
Writing: Firmware
Erasing: Eeprom
Writing: Eeprom
Write Done
Time used: 998 sec
Old 12-18-2007, 20:37   #4 (permalink)
Member: 130995
Hello,
so as I can understand, after flashing with files set 2 phone is in other condition than before ?
Try to charge phone battery (or at least check battery voltage). It may be that you need just charge battery now.
Old 12-19-2007, 11:40   #5 (permalink)
Mounir's Avatar
Member: 58969
Thanks Meter: 56
Thanx for your help (InfinitySupport )
After methode 2
-flashen met Backup eeprom (than s verything ok)
Old 12-19-2007, 13:37   #6 (permalink)
Member: 130995
Hello,
As I can understand, phone is alive. Is it right ?
If yes, please, tell me exactly what files you have used for repair, it will be useful for other users.
Thank you !
Old 12-19-2007, 14:52   #7 (permalink)
Mounir's Avatar
Member: 58969
Thanks Meter: 56
Hello,
Thank you !
-first i flashed with
Firm - KG375P16-FL-33-V10c_208-10_SEP-11-2007+2_firmware.B1M.bin
Lang Pack - KG75P16-FL-33-V10c_208-10_SEP-11-2007+2_LP.B1P.bin
FFS-2 - KG375_file_system_dffs_02.B1S.bin
Eeprom - KG375_repair_eeprom_02.B1E.bin
(phone blinken witk logo KG375) after that
-Second i flashed with
Eeprom - backup_eeprom-sec_35876301536225500_20071217-201638.B1E
***************phone work 100%*****************
*****************BACK ALIVE********************
The Following User Says Thank You to Mounir For This Useful Post:
Old 12-19-2007, 20:30   #8 (permalink)
Member: 148515
Thanks Meter: 19,249
hello!
thank you for sharing this info!
Old 01-09-2008, 21:51   #9 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
i have the same problem.. also killed by ULT
i flashed:
but now the phone is blinking at the kg375 logo
when i flash the backup_eeprom_sec file the phone is totaly dead again and not booting..
if i try the 1 option the phone is only blink without logo
any solution ?
Old 01-09-2008, 23:00   #10 (permalink)
ssa
ssa's Avatar
Member: 23420
Thanks Meter: 3,080
keept playing a while with the phone and selected
Unlock method 2 (airtel etc) and now the phone is booting and unlocked
very good job guys.. this saved me one refund of the phone to the customer
Old 01-10-2008, 00:27   #11 (permalink)
Member: 130995
@ssa
Thanks for report and new exparience !
@all
We are waiting for more eeprom backup files to [email protected]
This can helps to make our common file database for better repair results.
Old 01-29-2008, 18:05   #12 (permalink)
Member: 204684
Thanks Meter: 21
I just revived ma KG375 useing methog "Try #2:" (see above) then after that unlocked useing "direct unlock method #2 (Airtel etc.)". And then rebuild original imei. That's all.
Thanks to All
Old 02-08-2009, 15:32   #13 (permalink)
Member: 78744
Thanks Meter: 29
Hello,
Thank you !
very good work yes workd 100%
tested by my
tank you mounir
Huawei T202 After flash file on sp, phone was dead! duyphuong3000 Infinity-Box 23 01-19-2011 13:56
please help infinity team x70 dead after unlock nifboy Infinity-Box 4 04-28-2010 18:54
w220 flash eeprom with infinity phone dead! container Motorola ODM 4 01-04-2009 04:03
Checking whether phone was damaged after unlocking shl Nokia Base Band 5 ( BB-5 ) 4 06-08-2007 10:53
903sh-2006 was dead after unlock holong Sharp 3G (USB-Smart) 93 07-04-2006 07:55
Page generated in 0.20528 seconds with 9 queries
