KG800 UNLOCK - Always error Does infinity unlock KG800 see log: COM13 [VCP0] selected module v1.36 Device: LG-KG800 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... error: boot failed: Release Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 6 sec Remove/Install battery now ! |
reset full factory default. & then use sim wbr. rajesh ch. |
DId not work. Infinity box did not UNLOCK it at all. There was an error occured as shown in the LOG!!! |
Hello, Here is list of supported models: www.infinity-box.com If you want to see your model supported, please, try to select other models one by one and try to read flash. When you will be able to connect phone please, post here an information about connection process and we will try to check what is wrong with software. |
simple word ... MOBILE NOT SUPPORTED Br Faisal_Computer |
I think battery not have sufficient charge and also check cable.If everything ok then flash you phone then try again. |
