konka c625 unlock fail.. INFINITY, whats the wrong with the logs below? need your help urgent... COM5 [VCP0] selected Device: Konka C625 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection... Check connection done Set baud... Set baud done Check hardware... flash: 89887200010001:89887200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb Check hardware done Read data... reading Konka C625_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Konka C625_eeprom_calibration-1_20080326-122506.80E.bin Read data done Check data... Check data done Writing... Writing fail Finished, time used: 24 sec Remove/Install battery now ! |
Hello, Please, make this: 1. make "read flash" operation and send backup file to [email protected] to check 2. download from suppot area HModule v1.10 and try to unlock phone again Let's see results. |
i tried to unlock with the newer version but the problem still exist...before i upgrade to this newer version , i've done unlocking with 4 units....i tried to downgrade but same problem....is it possible that the unit has fault? |
Hello, Please, post here log with HModule 1.10. Also, make "read flash" operation and send backup file to [email protected] to check. As I can understand 4 phones unlocked and 1 is not unlocked. Is it correct or not ? |
yes your right...4 units successfully unlock...only 1 failed.... |
Hello, Backup file received, checking it now. Please, try to use HModule v1.10 and post here log with HModule 1.10, it's important to see it. |
Hello, Please, download new software http://www.infinity-box.biz/download...dule_v1.11.rar aand try to unlock phone again. Waiting for your results. |
wait....post result later....just testing the new update................ |
hey infinity....WHAT A GREAT UPDATE.....all done.......thanks , great team.... COM5 [VCP0] selected Device: Konka C625 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89887200010001:89887200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb Check hardware done Read data... reading Konka C625_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Konka C625_eeprom_calibration-1_20080327-094616.80E.bin Read data done Check data... pass-1... simlock structure #1 Check data done Writing... flash: 89887200010001:89887200000000 Write: eeprom Writing done Finished, time used: 73 sec Remove/Install battery now ! |
