konka c966 does not detect?? Hi all have one konka c966 have used this pinout but does not detect any one have ever unlock this model please. Cable name: Konka-C926-------on support is same as c966 keyboard top 1.........18 7: Phone Rx 9: Phone Tx 18: Gnd About my n73 thread i cannot find it.i have successfully repair it it was cable problem here is log and do u need the flash ???? COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.1D537D48.[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN_DFDC02D2].rpl New firmware detected: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification detection finished device-id: 1D537D48 protocol ver: 04 ver. sw1: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN ver. sw2: V2.0628.0.0.1 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN]]... file saved: backup_eeprom[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN]_20071029-100909.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: EC257E25082501:29EA0000000000 Write Done file saved: backup_system_log_1D537D48_SZMI26_05C_SET_PCB01_GP RS_MT6226_S01.V2_0628_0_0_1.BIN_DFDC02D2_20071029-100927.B0X.bin Finished, time used: 263 sec Remove/Install battery now ! |
have triple check cable all ok cannot understand why not connect .will try to solder on board directly let u know thanks .will send the n73 also by mail thanks for helping cheers yash |
You can try to swap Rx <-> Tx wires |
Have solder on board directly incase connector socket have problem.have also try to swap arx and tx as i always swap when not connect for 100% sure. I think this phone pinout is different.Thanks for helping ,if any other pinout please let me know. Thanks yash |
Can you check where is Gnd pin on phone connector ? |
pin 17 and 18 is ground |
this means tha this pinout should be correct: keyboard top 1.........18 7: Phone Rx 9: Phone Tx 18: Gnd |
